Which Brick Is Harder to Keep in Place: Brick A or B?
  • Thread starter Thread starter jcais
    Underwater
The discussion revolves around the buoyancy and stability of two bricks submerged underwater, with one brick (Brick A) positioned closer to the surface and the other (Brick B) deeper down. Participants explore the implications of pressure and buoyancy on the difficulty of keeping each brick in place.
  • Participants discuss the effects of water pressure and gravity on the stability of the bricks. Some question whether the wording of the original question might imply a trick, while others explore the implications of Archimedes' principle and the concept of buoyancy. There are inquiries about the scenario where the bricks rest on flat surfaces at different depths and how that might change the forces acting on them.
The conversation is ongoing, with various interpretations being explored. Some participants suggest that the question lacks clarity, while others provide insights into how the forces acting on the bricks might differ based on their depth and the presence of a flat surface. There is no explicit consensus, but several productive lines of reasoning have emerged.
Participants note that the question may be incomplete and discuss the implications of different scenarios, such as the presence of silt or coral, and the effects of water pressure at varying depths. The ambiguity in the question's wording is also highlighted as a point of concern.
jcais
Hello,
There are two bricks underwater. Brick A is closer to the surface and Brick B is further down below.
Which Brick would be hardest to keep in place?
I said Brick B because there is more pressure (H20) on it forcing it down + gravity.
Brick A just has gravity and a little bit of water pressure.
Am I right or wrong?
My friend agreed with me, but he said we could be wrong because it seems to easy...like a trick question.:rolleyes:
jcais said:
Hello,
It is a trick question. What do you know of Archimedes' principle ?
I googled it:
In physics, buoyancy is an upward force on an object immersed in a fluid (i.e. a liquid or a gas), enabling it to float or at least to appear to become lighter. If the buoyancy exceeds the weight, then the object floats; if the weight exceeds the buoyancy, the object sinks. If the buoyancy equals the weight, the body has neutral buoyancy and may remain at its level. ...
So, I am guessing that they are equal. Oh well, 5 points off of my test.
jcais said:
I googled it:
Yeah, the expected response is probably that they are equally "difficult/easy to keep in place". I do sympathise with you in that the wording of the question is poor - I would merely have asked which brick has a greater net force acting on it, which would've been clearer and more to the point.
Archimedes' principle states that a body immersed in a liquid experiences a buoyant force equal to the weight of the fluid it displaces. For a particular object with a particular volume, this weight of fluid will be the same, hence the buoyant force will be the same, no matter where it is in the fluid medium (even its orientation doesn't matter).
Now I'm curious about something. What if each brick is resting on a flat surface at the different depths? Is the answer still the same? I can see that the force will be the same if there is water (and hence water pressure force) on the underside of each brick, but what if there is no water? Then the downward force on each brick would seem to be different, since the water pressure is higher at the greater depth... Help me out here?
In the case of rigid supports in contact with the underside of the bricks, I believe the situation will be different. Let's say there're two strong flat pedestals attached to rigid beams that're firmly planted in a foundation in the bed of the water body. The two pedestals are of different heights. In this case, I would expect that the water pressure on the top surface is unbalanced (the sides cancel out). The brick that is deeper down (on the shorter pedestal) has a greater unbalanced force acting to push it downward, leading to greater stability and greater "apparent weight" if one tries to lift it off the pedestal.
So now you don't have to worry about losing any points on the question! The question was incomplete. If the bricks were sitting in silt or on coral, the upward force to lift them would be the same, independent of depth. If they are sitting on an artificial flat surface where there is no water between then and the flat surface, then the force required to lift them increases with depth. Go to your prof now and get some extra credit points added! And be sure to mention PF as a source. :biggrin:
See, this is what happens when you allow "normal" people - non-obsessive-compulsives - to set questions. :biggrin:
I'm terribly obsessive about the wording of any questions I pose or set. Having someone else point out an ambiguity or loophole would be unbearable. I guess I'll never make a good teacher or test-setter, it would just take me too long to get the wording just right. Also, the questions might end up being longer than the answers! :smile:
This all brings up an interesting thought experiment...
So if it's true what Curious and I are saying about the brick being harder to pull off of a flat surface at deeper depths, then it should also be true that when you are deep enough, the brick will stick to the flat surface even if the surface is tilted vertical, and even at some depth if the surface is inverted...?
So take a smooth-sided brick and place it on a piece of smooth-sided panel while you are out of the water at the surface. The smooth surfaces are in intimate enough contact so that water will not be able to get between the brick and the panel. Now descend to some depth d. Water pressure starts at 1ATM at the surface, and increases by 1ATM for every 10m or so of depth. Can we find some minimum depth d where we can turn the panel over and let go of the brick, and it will still stay stuck to the panel?
Should be simple enough: The force due to water pressure must equal the weight of the brick. When the brick/panel is upside down, only the bottom surface of the brick counts.
Edit: Now that I think about it, if the seal between brick and panel were airtight, air pressure alone would probably hold the brick in place. :smile:
  • · Replies 17 ·
15K
