What is the solution to the classical string problem?
  • Context: Undergrad
  • Thread starter Thread starter Loren Booda
    Classical String
The discussion revolves around a classical physics problem involving a flexible string, half of which lies on a frictionless table while the other half hangs off the edge. Participants explore whether the problem can be solved using classical physics alone or if quantum mechanics is necessary, particularly focusing on the time it takes for the string to slip completely over the edge.
  • One participant proposes a differential equation based on the net force acting on the string, suggesting that the weight of the hanging portion influences the motion.
  • Another participant clarifies that the initial conditions involve static equilibrium, indicating that the weight of the hanging string is balanced by friction, and questions how to initiate motion.
  • A different viewpoint suggests that an infinitesimal impulse might be needed to start the motion, raising the possibility of quantum mechanical considerations affecting the problem.
  • Concerns are raised about the lack of information regarding kinetic friction characteristics, which complicates the dynamics of the problem.
  • One participant expresses uncertainty about the solution and indicates a willingness to defer to others for further insights.
Participants do not reach a consensus on how to approach the problem or whether classical or quantum mechanics is necessary. Multiple competing views remain regarding the initial conditions and the role of friction.
Limitations include the unclear nature of the friction model applicable to the problem and the dependence on initial conditions that are not fully specified. The discussion reflects uncertainty about the dynamics once the string begins to move.
Loren Booda
Classical "string" problem
My freshman physics class was given the following problem. I can't remember if it can be solved by classical physics alone, or else needs a quantum mechanical start:
Half of a perfectly flexible string of length L and negligible width lies straight and motionless on an exactly horizontal (to gravity) frictionless table, while the other half hangs freely from its edge. How much time transpires until the string slips completely over the edge?
There's probably a better way to do this, but I'd try this:
[tex]F_{\rm net} = m\ddot{x} = \frac{\frac{L}{2}+x}{L}mg[/tex]
where x is the distance between the end of the rope on the table and its starting point. The net force on the rope is just the weight of the fraction of the rope that is hanging off the table. If you solve that differential equation and find the time when x = L/2, that should be the answer.
jamesrc,
Sorry, I think I misstated the problem. The weight of the hanging string is initially counterbalanced exactly by the friction of its other half lying on the table. How much time transpires until the string slips completely over the edge?
The system is in classical (albeit singular) equilibrium, but needs an infinitesimal impulse, perhaps quantal, to get started. Taking Q. M. into account, is there a standard answer to this problem or a distribution of possible times, given the minimum information needed?
Oh, I thought the table was frictionless and the rope was held until t = 0, when it was released. As it is now stated, I'm not sure how to go about solving the problem. It seems to me that the initial static equilibrium conditions will not help you solve the dynamics, since you know nothing about the kinetic friction characteristics (you would expect, for a Coulomb model of friction, that &mu;k < &mu;s). And since the rope is so idealized, I don't see how/why you could/would employ a more sophisticated friction model (well, maybe viscous, but I don't see a compelling reason to).
Anyway, once it starts (and it wouldn't matter how it started as long as it wasn't given an initial velocity), it should keep accelerating and should be solvable using differential equation similar to the one from my other post (with a friction term in there).
I guess in short, I don't know, so I'll defer to those who do and check into see how this develops.
  • · Replies 62 ·
11K
