Specific Heat Capacity Problem.(Please check.)
The discussion centers on a calorimetry problem involving a 0.050 kg metal bolt and 0.15 kg of water. The specific heat capacity of the metal is 899 J/kg°C, and the final temperature of both substances is 25.0°C. The initial temperature of the metal is calculated to be -30.87°C, but the book states it as +80.87°C due to a sign error in the heat transfer equation. The correct relationship indicates that the heat gained by the water equals the heat lost by the metal, leading to the conclusion that the initial temperature of the metal is indeed +80.87°C.
  • Understanding of specific heat capacity
  • Knowledge of calorimetry principles
  • Familiarity with heat transfer equations
  • Basic algebra for solving equations
  • Study the principles of heat transfer in calorimetry
  • Learn about the conservation of energy in thermal systems
  • Explore specific heat capacity calculations in different materials
  • Investigate common calorimetry problems and solutions
Educators, physics students, and anyone interested in thermodynamics and calorimetry principles will benefit from this discussion.
shulien
This is CALORIMETRY PROBLEM.
A 0.050kg metal bolt is heated to an unknown initial temperature. It is then dropped into a beaker containing 0.15kg of water with an initial temperature of 21.0 C. The bolt and metal then reach a final temperature of 25.0 C. If the metal has a specific heat capacity of 899 J/kg*C, find the initial temperature of the metal.
the solution is:
Change in Temp of metal = (C of water *mass of water* Change in temp of water)/(C of metal*mass of metal)
Change of temp. of metal = [(4186 J/kg*C)(0.15kg)(25C-21C)]/[(899 j/kg*C)(0.050kg)
Change of temp. of metal = 55.87C
Change in temperature = Final Temperature-Initial Temperature
Initial Temperature = Final Temp.-Change in Temp
=25C-55.87C
= -30.87C
i want to ask why is the answer +80.87C from the book, instead of -30.87C?
i hope you could explain so i can also explain it to my students. is the sign of the answer has something to do with the HEAT REMOVAL and HEAT ABSORPTION?
Thanks!
shulien said:
the solution is:
This is off by a minus sign. The net change in thermal energy of "metal + water" is zero, so:
Change in Temp of metal = - (C of water *mass of water* Change in temp of water)/(C of metal*mass of metal)
Change of temp. of metal = [(4186 J/kg*C)(0.15kg)(25C-21C)/[(899 j/kg*C)(0.050kg)
The change in temp of the metal is -55.87C, not +. (The metal cools down.)
=25C-55.87C
= -30.87C
25C - (-55.87C) = +80.87C
Just keep in mind that the "heat" gained by the water must equal the "heat" removed from the metal. In terms of Q: For the water, Q = + (it heats up); for the metal, Q = - (it cools down). The net Q is zero.
thanks for the reply.
:smile:
10K
