Relationship between velcity, wavelength, and frequency
The discussion revolves around the relationship between velocity, wavelength, and frequency of waves as they transition between different media, specifically air and water. Participants explore how these quantities interact and whether certain values remain constant across mediums.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants question how velocity, wavelength, and frequency behave when moving from one medium to another, and whether frequency remains constant. There are discussions about the implications of the wave equation and its application in different contexts.
Several participants have provided insights regarding the constancy of frequency when transitioning between media, while others have raised questions about the implications of this for wave behavior. The conversation is exploring various interpretations of the wave equation and its relevance in different scenarios.
Some participants mention the need for clarity on the definitions of terms like "source" in relation to wave generation, and there are references to specific types of waves, such as electromagnetic waves and sound waves, which may influence the discussion's direction.
Dunkaroos
what happens to the velocity, wavelength, and frequency as you pass from air to water?
water to air?
air to air?
water to water?
One book tells me that veolocity is kept constant only within a single medium while another book says that these 3 quantities ALWAYS obey the equation (velcity = wavelength*fequency)
Also, is there a special name for this formula?
:rolleyes: Thank You VERY much for reading/helping!
water to air?
air to air?
water to water?
What do you think? Hint: One of those three remains constant.
Both are true statements. That equation is often loosely called the "wave equation".
Once in a homogeneous medium, the three quantities are related by that equation as shown. BTW, I can never remember the equation, so I use the units of the three quantities to help me get it right:
v [m/s] = wavelength [m] * frequency [1/s]
When passing from one medium to another (or to different densities within the same medium), these quantities can change. If the transition is over a distance which is much greater than a wavelength (like as sound goes straight up in the atmosphere into thinner and thinner air), then this equation still holds at any particular spot. But if the transition zone is on the order of a wavelength, I don't think that the equation is very meaningful at the transition (I could be wrong about that though).
So how does the speed of sound vary with the density of the air? Does sound go faster in water or air? You can goodle those pretty easily if you don't know already.
water to air?
air to air?
water to water?
You are taking about an electromagnetic wave?
In any case, both of your books are right.
The key point is that the frequency does not change when the wave changes medium. But both the speed and the wavelength will change in such a way that the equation that you wrote remains satisfied in all media.
(I am not aware of any special name for this equation...It's the equation for the speed of a sinusoidal wave).
Yes, electromagnetic.
Can it be concluded that the frequency of a particular wave usually remains the same?Lets say I two waves (a 1m wavelength waveand a 2m wavelength wave) start in the same position and end in the same position. Which one will reach the end position?
Since both waves are traveling through the same medium (air), won't the velocities of the 2 waves be the same? Can I say that the velocity is independent of wavelength and frequency in a single medium?
^_^!
Frequency is determined by the source.
~H
What do you mean by source? Example?
^_^!
yes, when a wave changes medium, the frequency remains the same.
And yes, the speed is determined by the properties of the medium (for an em wave, the speed is c/n where n is the index of refraction. For a wave on a string, the speed is the square root of (the tension over the linear mass density), for a sound wave, the speed depends on the bulk modulus and the volume mass density, etc.
A speaker for sound. A light bulb for photons. An antenna for E&M. A binary star for gravity waves.
  • · Replies 22 ·
  • · Replies 31 ·
13K
