How to Find the Area Bounded by a Hypocycloid Equation?
  • Thread starter Thread starter Reshma
    Area Bounded
The discussion revolves around finding the area bounded by a hypocycloid defined by the equation x^{3/2} + y^{3/2} = a^{3/2}. Participants explore various approaches to evaluate the area using polar coordinates and parametric representations.
  • The original poster attempts to use polar coordinates but is unsure about setting up the surface integral for area calculation. Some participants clarify the need for a proper polar representation and suggest using parametric equations for the hypocycloid. Others question the correctness of the original equation and its implications for the area calculation.
The discussion is active, with participants providing guidance on converting integrals to polar coordinates and discussing the implications of using parametric representations. There are differing views on the correctness of the initial equation and its representation, leading to further exploration of the problem.
Participants note that the original equation may only be valid in the first quadrant, raising questions about the domain of integration and the assumptions underlying the area calculation.
Reshma
Equation of a hypocycloid is:
[tex]x^{3/2} + y^{3/2} = a^{3/2}[/tex].
Find the area of the figure bounded by this hypocycloid.
My work:
I can use the plane polar coordinates here taking [itex]x = a\cos t[/itex] & [itex]y = a\sin t[/itex] with [itex]t = [0, 2\pi][/itex]. But I don't know how to obtain the surface integral for evaluating the area ( :blushing:) . Someone help me.
First of all, you've not used plane polar coordinates. When you say [itex]x = a\cos t[/itex] & [itex]y = a\sin t[/itex], you have just given a parametric representation of any point (x,y) lying on the curve.
When you integrate to find the area, your domain of integration is going to include points lying inside the curve also. So, you need to use the polar coordinates [itex]x= r \cos \theta[/itex] and [itex]y=r \sin \theta[/itex].
Now, your integral will be
[tex]\int \int dx dy[/tex]
Convert this integral to polar coordinates. Can you take it from here?
Well in any case [itex]\int \int dx dy[/itex] the cannot be applied here since it completely ignores the equation of the given curve. The parametric representation of a hypocycloid will be:
[tex]x = a\cos^3 t , y = a\sin^3 t[/tex]
[tex]dx = -3a\cos^2 t\sin tdt, dy = 3a\sin^2 t\cos t dt[/tex]
So the formula representing the area of a curvilinear trapezoid bounded by a curve represented parametrically is:
[tex]Q = \int_0^{2\pi} ydx = \int_0^{2\pi} a\sin^3 t(-3a\cos^2 t\sin t)dt =-3a^2\int_0^{2\pi} \sin^4 t\cos^2 tdt[/tex]
Someone just help me crack this integral, I am not very far from the answer i.e. [itex]{3\over 8}\pi a^2[/itex].
Looks to me like a standard "even powers of trig functions". Use the identities: sin2x= (1/2)(1- cos(2x)) and cos2= (1/2)(1+ cos(2x)) to reduce the powers.
These do not agree (plug in with e.g. t = 2, a = 1 to verify). You want your x to be such that x^(3/2) = a^(3/2) * cos^2 t and your y to satisfy y^(3/2) = a^(3/2) * sin^2 t.
Or is your original equation correct? It would only be defined for values in the first quadrant.
  • · Replies 20 ·
  • · Replies 19 ·
