Linear Algebra Test Prep: Determining Subspaces of Matnxn
  • Context: Undergrad
  • Thread starter Thread starter fasterthanjoao
    Subspace
The discussion revolves around identifying which subsets of Matn×n qualify as subspaces of the vector space of n x n matrices. Participants explore various types of matrices, including symmetric, skew-symmetric, orthogonal, singular, invertible, echelon, and reduced echelon matrices, and their properties in relation to subspace criteria.
  • Some participants assert that to determine if a subset is a subspace, one must check if it is closed under addition and scalar multiplication.
  • One participant claims that symmetric matrices form a subspace, providing reasoning based on the properties of symmetric matrices under addition and scalar multiplication.
  • Another participant questions the relevance of singularity in determining subspaces, suggesting that the ability to reduce matrices to echelon form indicates linear independence but may not be sufficient for subspace criteria.
  • Concerns are raised about whether the closure properties apply to invertible matrices, with a participant suggesting that adding two invertible matrices does not guarantee the result is also invertible.
  • A participant emphasizes the importance of definitions and suggests finding counterexamples if closure properties cannot be proven.
  • Discussion includes the nature of linear operations and their implications for subspaces, particularly regarding the determinant function and its linearity.
Participants express differing views on which subsets qualify as subspaces, with no consensus reached on the status of singular and invertible matrices. The discussion remains unresolved regarding the implications of matrix properties on subspace classification.
Participants highlight the need for careful consideration of definitions and properties, particularly regarding the linearity of operations and the implications of matrix singularity. The discussion reflects uncertainty about the relationships between different types of matrices and their classification as subspaces.
fasterthanjoao
I'm preparing for an end of year linear algebra test which briefly covers things about subsets of Matnxn and their relations to subspaces of Matnxn; I found the following question:
Which of the following subsets of Matn×n are subspaces of Matn×n?
(i) Symmetric matrices (i.e. matrices A such that AT = A).
(ii) Skew-symmetric matrices (i.e. matrices A such that AT = −A).
(iii) Orthogonal matrices (i.e. matrices A such that AT = A−1).
(iv) Singular matrices.
(v) Invertible matrices.
(vi) Echelon matrices.
(vii) Reduced echelon matrices.
I'd appreciate some guidance on how to tell which of the above apply.. is it the same as showing that vectors in a subset are subspaces when they're closed under addition and linear multiplication?
thanks.
Yes, the matrices are the vectors of the vectorspace Mat(nxn).
For example, (i) is a subspace, because:
If A and B are symmetric and r a scalar, then A^t=A, B^t=B. So (A+B)^t=A^t + B^t = A+B is symmetric and (r A)^t = r A^t = r A is symmetric.
thanks.
Exactly where do you struggle? It would be helpful for you to write out your attempt at showing one of them is, or isn't, a subspace, so we can see where you have problems.
1. Is it the definition of a subspace?
2. Is it in seeing whether these will or will not be subspaces?
3. Is it in writing out a proof?
which also, clearly, means I can't write a proof. It seems as though all that's needed is to check whether they're closed under addition and multiplication. I don't see how the fact that a matrix is singular or non is relevant. The fact that a matrix can be reduced to echelon form shows the vectors it represents are linearly independent but is there anything else that needs said from there? Can the same be said of a reduced echelon form? the only difference is that the echelon form represents a less trivial basis?
The usual subspace tests apply, your matrices are 'vectors'. You're thinking of Matn×n as a vector space after all.
If you add two invertible matrices do you always end up with an invertible matrix?
Firstly, it does not refer anywhere to the set of matrices that *can* be put in row echelon form, it refers to the matrices that *are* in row echelon form. Every matrix *can* be put in (reduced) row echelon form by row operations.
If I remember correctly reduced echelon form is where the first non-zero entry in any row is a 1. Take some matrix of that form. Do you think that every scalar mutliple of such a matrix will have a 1 as its first nonzero entry?
One obvious thing to check is if 0 is in the subspace.So, step 1. Try and prove that the definitions hold. If you can't prove it from the definitions of the *subset* try and find a counter example. In simple cases like this if you can't do the former easily, then it must fail to be a subspace. Find the/a reason.
It is impossible to prove that A invertible and B invertible implies A+B is invertible, isn't it? So try and find a counter example. (Of course it fails for an easier reason than that to be a subspace, as I've already alluded to.) Whereas it is easy to show that if A is symmetric and B is symmetric then so is A+B (and tA for any scalar t).
Answers in maths (beyond high school) shouldn't just don't jump out at you I'm afraid (unless you happen to be exceptional), you need to sit and stare at the questions for a while and play around with things until you see what's going on. If you don't see what singular or nonsingular has to do with the vector space structure then it's a good bet that the singular or nonsingular matrices are not a subspace. Singularity is a property of multiplication and therefore not necessarily going to be respected by addition.
basically inverse images of linear functions and linear operations, are flat like subspaces, and inverse images under more complicated operations are not.
forming a transpose is a linear operation so the inverse image of zero under A-At is a subspace. multiplication is not linear, so the inverse image of the identity under the product AAt is not a subspace, also we are taking the inverse image of 1 not zero.
the singular matrices are the inverse image of zero, but under the determinant function. does that function seem linear to you? what is the degree of the determinant as a function of the entries?
etc etc...
