Calculating Water Pressure: A Puzzle to Solve
The discussion revolves around calculating water pressure in a system involving columns of water with varying diameters. Participants explore the relationship between the diameter of tubes and the pressure exerted by water at different depths.
  • Participants discuss the formula for pressure as Force/Area and question how changes in tube diameter affect pressure. There is an exploration of whether the weight of water above influences pressure in smaller tubes.
Some participants have provided guidance on the principles of fluid pressure, emphasizing that pressure is dependent on depth rather than total weight. There is ongoing clarification regarding the effects of tube diameter on pressure, with multiple interpretations being considered.
Participants are navigating assumptions about fluid dynamics and the conditions under which pressure calculations are valid, particularly in relation to unobstructed columns of water.
Idea04
To determine the pressure of water, you would use Force/Area. With a column of water. For example a 4 inch diameter column of water with 24 pounds of water in it. Equation would be 24/12.56637061. Would equal 1.909 psi. But if at the bottom of the column there was a 1 inch diameter tube. Would you take 24 pounds and divide it by the area of 1 inch-(0.785398163 cubic inches) to get the pressure leaving the tube.
If that were true would the pressure be 30.55774909psi? It just doesn't seem right. Can someone help me with this?
It's not right. The static pressure exerted by a fluid depends on how deep you are below its surface, not on the total weight of all the fluid above you. (For example: A small bucket with a foot of water in it and an olympic size swimming pool with a foot of water in it both have the same water pressure acting on their bottom surfaces.) You can only use "weight of the column of fluid/Area" to find the pressure if the column of fluid is straight and unobstructed. Read this: http://hyperphysics.phy-astr.gsu.edu/hbase/pflu.html
What I would like to know is that a column of water 7 feet tall, that is staight and unobstructed. Then there would be pressure from the weight of the water above you. But does the pressure increase when it goes from a large tube 4 inches to a small tube of 1 inch diameter. Because with the equation F/A for a large tube the weight is 77.9 pounds. But with a surface area of 12.5 cubic inches. And for the small tube of 77.9 pounds above it and .785 cubic inches. Remember that the large tube flows vertically to the small tube by gravitational force.
Once again, the answer is no. The 1 inch diameter area supports only a 1 inch diameter column of water; the rest of the 7 foot tall column is supported by the bottom of the 4 inch diameter section of tube. (Please read the link I gave in my last post.)
  • · Replies 74 ·
  • · Replies 29 ·
