Solving Stokes Theorem Problem: F(x,y,z)
The discussion revolves around the application of Stokes' Theorem to a vector field F(x,y,z) = <2y,3z,-2x> over a surface defined by the unit sphere in the first octant. Participants are exploring the calculation of the curl of the vector field and its implications for evaluating a surface integral.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to evaluate the double integral using cylindrical coordinates and expresses confusion about their approach. They question the correctness of their substitutions and the evaluation process.
  • Some participants discuss the meaning of the vector dS and its role in the context of Stokes' Theorem, raising questions about how to compute the dot product with the curl of the vector field.
  • Others suggest using spherical coordinates to parameterize the surface and provide derivatives for the parameterization, leading to a discussion on the cross product and its application in finding the vector differential of surface area.
The discussion is active, with participants providing insights and clarifications on various aspects of Stokes' Theorem and surface integrals. There is an exploration of different parameterization methods and the implications of the dot product in the context of the problem. No consensus has been reached, but several lines of reasoning are being examined.
Participants are working under the constraints of a homework problem, which may limit the information available for discussion. The original poster expresses uncertainty about their approach and seeks clarification on specific concepts related to the theorem.
dzza
Hi, i can't seem to figure out how stokes theorem works. I've run through a lot of examples but i still am not having any luck. Anyway, some advice on a particular problem would be greatly appreciated.
The problem is: F(x,y,z) = <2y,3z,-2x>. The surface is the part of the unit sphere in the first octant; the normal vector n is directed upward.
I get that the curl of F is <-3,2,-2>. What I tried next was writing the equation for the sphere as z = f(x,y) = sqrt(1-x^2-y^2) and finding from that fx(x,y) and fy(x,y). I then tried evaluating the double integral in cylindrical coordinates over R of (3fx-2fy-2)dA, where R is the region from 0 to pi/2 and r = 0 to r=1. I changed all the x's and y's to their polar equivalents and didn't forget the r in the dA or anything. I got nothing close to the right answer.
I understand that the way i approached it might be flawed, so if you can help in either helping me understand why what i was doing is wrong or if you have a different way of approaching it i would greatly appreciate the help. Thanks
Work you way through the problem systematically. What is Stoke's Theorem?
[tex]\iint_S \nabla \times \vec F \cdot d\vec S[/tex]
What does [tex]d\vec S[/tex] mean?
[tex]d\vec S = \hat n \,\,dS[/tex]
So what do you have now?
[tex]\iint_S \nabla \times \vec F \cdot \hat n \,\,dS[/tex]
Now finding the curl is straightfoward, thus:
[tex]\iint_S \nabla \times \vec F \cdot d\vec S= \iint_S (-3,2,-2) \cdot \hat n \,\, dS[/tex]
What's a general expression for solving a surface integral?
This one works right?
[tex]\iint_S f(x,y,z)\,\,dS = \iint_D f(x,y,g(x,y))\sqrt{\left(\frac{\partial z}{\partial x}\right)^2 + \left( \frac{\partial z}{\partial y} \right)^2}\,\,dA[/tex]
Why does this work?
Well when you take the dot product of two vectors, what do you get? Yup... a scalar. And f(x,y,z) doesn't return a vector right?
So what is the unit vector? And then what happens when you take the dot product? What would f(x,y,z) equal?
so, what exactly does d(vector)S represent? How do I get a vector to dot with curl(vector)F? My particular problem has a circle in 3-space, with z=1. The formula above is for when one is given an equation in form of z=g(x,y).
[tex]d\vec{S}[/tex] is an infinitesemal vector normal to the surface with magnitude equal to the area of the parallellogram spanned by two linearly independent tangent vectors of infinitesemal magnitudes.
Use the "fundamental vector product": the surface of the unit sphere can be written in terms of 2 parameters, the two angles in spherical coordinates: [itex]x= cos(\theta)sin(\phi)[/itex], [itex]y= sin(\theta)sin(\phi)[/itex], [itex]z= cos(\phi)[/itex].
The derivatives of <x, y, z> with respect to [itex]\theta[/itex] and [itex]\phi[/itex] are the vectors
[tex]<-sin(\theta)sin(\phi), cos(\theta)sin(\phi), 0>[/tex]
and
[tex]<cos(\theta)cos(\phi), sin(\theta)cos(\phi),-sin(\phi)>[/tex]
The "fundamental vector product" is the cross product of those:
[tex]<cos(\theta)sin^2(\phi),sin(\theta)sin^2(\phi),sin(\phi)cos(\phi)>[/tex]
(positive since it is oriented upward).
Finally, the vector differential of surface area is
[tex]<cos(\theta)sin^2(\phi),sin(\theta)sin^2(\phi),sin(\phi)cos(\phi)>d\theta d\phi[/tex]
  • · Replies 21 ·
