| Thread Closed |
A system of two second order differential equations |
Share Thread | Thread Tools |
| May9-06, 09:50 AM | #1 |
I was wondering what the best method is to solve two second order differential equations that are coupled. I need to solve it by hand and write my own code so I cannot use built in functions in matlab, etc. At time (0), displacement and velocity are 0 with an initial acceleration which is dependent on pressure as a function of time.
| May11-06, 02:12 AM | #2 |
Recognitions:
Perhaps a little more detail would be helpful. Are these ordinary DEs? Linear? Homogeneous?
| May11-06, 02:31 AM | #3 |
...and...
Is it a computational project? What language do you use? fwiw, if it is, just write a simple Euler integration code (after putting the equations into first order form), see if it works and then compare with results from an RK4 code... |
| May11-06, 01:10 PM | #4 |
I didn't know that I could put them into 4 first order equations, but I did it and it worked fine. Thank you.
| Thread Closed |
| Thread Tools | |
Similar Threads for: A system of two second order differential equations
| System of Second Order, Nonhomogeneous Differential Equations | Differential Equations | 3 | ||
| differential equations-system of equations, cleaning up the great lakes... | Calculus & Beyond Homework | 1 | ||
| second order system of differential equations in Matlab | Math & Science Software | 11 | ||
| First Order Differential Equations | Calculus & Beyond Homework | 1 | ||
| First Order Differential Equations | Calculus & Beyond Homework | 19 | ||
