Check My Work: 100kg Mass Moving in a Straight Line
The discussion centers on calculating the speed of a 100 kg mass moving under a force defined by F(t) = (120 N/s)t + 4000 N at t = 5.00 s. The initial speed is 0 m/s, and the calculated force at t = 5.00 s is 4600 N, leading to a final speed of 230 m/s using the formula V = (FΔt)/M. Participants emphasize the importance of considering the average force over the time interval rather than just the maximum force applied.
  • Understanding of Newton's Second Law of Motion
  • Basic calculus for integrating force functions
  • Knowledge of kinematics and motion equations
  • Familiarity with units of force (Newtons) and mass (kilograms)
  • Study the concept of average force in physics
  • Learn about integration techniques for calculating work done by variable forces
  • Explore Newton's laws of motion in greater detail
  • Investigate the implications of using maximum vs. average values in physics problems
Physics students, educators, and anyone interested in classical mechanics and the application of Newton's laws in real-world scenarios.
positive infinity
I was wondering if someone could check my work and see if its correct.
An object of mass 100.00kg moves in a straight line under the influence of a force given by F(t)=(120 N/s)t+4000N
At t=0 it is moving at 0 m/s. Determine its speed at t=5.00 s
What i did is this. I plugged 5s into the function and got 4600N. Then i used F▲V=M▲V arranged to V=(F▲T)/M
V=(4600N X 5.00s)/100.0kg
V=230. M/S
Thank you
[tex]\int_{0}^{5} (120t + 4000)dt = m \int_{0}^{v} dv[/tex]
I hope that you meant F ▲t = m ▲v ... which DOES lead to ▲V = (F▲t)/m .
. . . ("change" symbols in an equation should ALWAYS balance) . . .
But why would you use the strongest Force in the 5-second duration?
Why not use the weakest Force, instead? . . . why not use the AVERAGE ?
. . . (ALWAYS multiply one's full range by the other's average) . . .
  • · Replies 98 ·
  • · Replies 27 ·
