What Does the Big F Represent in Equations?
  • Context: Undergrad
  • Thread starter Thread starter Line
The discussion revolves around the meaning of the symbol "F" in mathematical equations, particularly in the context of the Fundamental Theorem of Calculus and its relation to antiderivatives. Participants explore various interpretations and conventions surrounding the use of capital and lowercase letters in mathematical notation.
  • Some participants suggest that "big F" typically represents the antiderivative of "little f" in the context of calculus.
  • One participant questions the original equation provided, proposing that it might be a misrepresentation of the integral form of the Fundamental Theorem of Calculus.
  • Another participant confirms that the convention of using uppercase letters for antiderivatives is common but not mandatory.
  • Some humorously suggest alternative meanings for "F," referencing cultural phrases unrelated to mathematics.
  • There is a discussion about defining "F(x)" in a specific context, indicating that it can also represent a function derived from other functions rather than an antiderivative.
  • A participant asserts a unique definition for "F(x)" that does not align with the conventional understanding of antiderivatives.
Participants express differing views on the meaning of "F" and its conventional use, with no consensus reached on its interpretation in the original equation. The discussion includes both support for and challenges to the standard conventions of mathematical notation.
There are unresolved assumptions regarding the context in which "F" is used, and the discussion highlights the variability in mathematical notation and definitions across different contexts.
Line
What does the big F stand for in equations like
f(x)-sinb=F(a)-F(b) ??
It's not like the little f in function.
Typically, textbooks discussing the Fundamental Theorem of Calculus
refer to F(x) ("big F") as the antiderivative of f(x) ("little f").
*This link might help :smile:
"f(x)-sinb=F(a)-F(b)" makes no sense. Are you sure it wasn't something like [itex]\int_b^a f(x)dx= F(a)- F(b)[/itex]?
SO a capital F means the antiderivative of a function?
By convention, if we use a lower-case letter to denote a function, we use an upper-case letter to denote its anti-derivative.
It's not something you have to do -- it's just something that people usually do because everyone else does it and it's convenient.
according to some bumper stickers i have seen, it stands for the president.
With "_ _ _" after it?
I've seen this used as follows
f(x)=x^2
g(x)=x/2
F(x)=f(x)/(g(x)
Other than that, doesn't ring a bell.
EDIT: What math class did you see this in?
Did you mean to type anything else? I didn't see a closed parenthesis. If it is indeed so, then the F(x) you saw does not refer to any antiderivative, but simply f(x) / g(x). As Hurkyl said below, the antiderivative notation is simply convention, and not a strict rule of mathematics.
f(x)=x^2
g(x)=x/2
F(x)=f(x)/g(x)
That is simply defining F(x) to be f(x)/g(x)- making it clear that the convention "F(x) is an anti-derivative of f(x)" is not being used!
Actually, I hereby declare that the following definition of F(x) is unique and unviolable:
[tex]F(x)=\frac{\pi}{1+\frac{\pi}{1+\frac{x}{e+\pi}}}[/tex]
  • · Replies 17 ·
