What are the properties of matrices and their powers?
This discussion addresses two specific problems related to matrix operations. The first problem involves determining an elementary matrix that scales the third row of a 3x3 matrix A by 2/3, requiring the construction of a matrix B such that BA results in the desired transformation. The second problem focuses on eigenvalues and eigenvectors, specifically proving that if v is an eigenvector of matrix A associated with eigenvalue lambda, then v is also an eigenvector of A^2 with the associated eigenvalue lambda^2.
  • Understanding of elementary matrices and their operations
  • Knowledge of eigenvalues and eigenvectors
  • Familiarity with matrix multiplication
  • Concept of matrix powers, specifically A^2
  • Study the construction and properties of elementary matrices
  • Learn about eigenvalues and eigenvectors in depth
  • Explore the implications of matrix powers on eigenvectors
  • Investigate the relationship between matrix transformations and their effects on rows
Students and educators in linear algebra, mathematicians focusing on matrix theory, and anyone seeking to deepen their understanding of matrix properties and eigenvalue problems.
Max Power
I have a few problems at which I'm at a loss.
The first problem asks to "determine the elementary matrix that will multiply the third row of a 3x3 matrix by 2/3". I'm not even sure what this problem is asking. If A is a 3x3, is this problem asking for a matrix, B, which when you do AB, the third row of A is multplied by 2/3?
The second problem says "Let lambda be an eigenvalue and v an associated eigenvector of matrix A. Prove that v is also an eigenvector for A^2. What is the associated eigenvlue?" I can't find anything about the properties of matrices and their powers?
Might someone be able to offer a nudge or push in the right direction for either of these problems?
Thank you.
The second question is asking, if Av= lambdav, with lambda the eigenvlaue and v the associated eigenvector, prove that v is also an eigenvecotr for A^2, or A^2v = deltav, with delta the eigenvalue.
As for the first question, it's asking for a matrix B such that the third row of A is 2/3 its original value when you calculate BA.
  • · Replies 25 ·
