How does steady state refrigeration work?
Steady state refrigeration is the operational state of a refrigerator where it maintains a constant internal temperature by balancing heat removal and heat leakage. The compressor operates primarily at a constant workload, adjusting its efficiency based on the temperature differential between the internal and external environments. A thermocouple control mechanism regulates the compressor's activity, activating it when the internal temperature rises above the set point. Key factors influencing this process include heat conduction, convection, and the efficiency of heat transfer.
  • Understanding of thermodynamics principles, particularly heat transfer.
  • Familiarity with refrigeration cycle components, including compressors and thermocouples.
  • Knowledge of temperature differentials and their impact on heat leakage.
  • Basic grasp of residential refrigeration systems and their operational mechanics.
  • Research the refrigeration cycle and its components in detail.
  • Learn about thermocouple control mechanisms and their applications in temperature regulation.
  • Investigate the principles of heat transfer efficiency in refrigeration systems.
  • Explore the effects of temperature differentials on heat leakage in refrigeration.
Engineers, HVAC technicians, and students studying thermodynamics or refrigeration systems will benefit from this discussion, as it provides insights into the mechanics of steady state refrigeration and its operational efficiency.
Bonulo
When a refrigerator has been turned on for some time, steady state refrigeration occurs. This is the normal refrigerator operative state. But what exactly happens?
These things are really hard to do research on, since Internet searches, regardless of search query detailing, result in a lot of useless sites. Our textbook, University Physics 11th Ed., has nothing on the subject.
Does the compressor
1. lower its amount of work done on the refrigerant so much, that the refrigerator cools as quickly as heat conduction heats the food? (I don't think so)
2. lower its amount of work for some time, when the temperature gets a bit too cool, then increase it, when the temperature gets a bit too hot, and continue this way, steadily lowering and increasing its work? (This has been suggested to us)
3. reverse the process for some time (so that heat is pumped into, instead of out of the refrigerator) and continue steadily reversing the process? (This too has been suggested)
Under steady-state operation, a refrigerator removes as much heat from the cold region as leaks back in from the environment. The in-leakage of heat depends on the temperature differential, or more commonly, convection of cold atmosphere out which is displaced by warmer air (as when one opens the door). There is a thermocouple control which shuts of the compressor once the desired temperature is achieved, and thereafter, the control will activate the compressor once a warmer temperature is acheived.
Compressor work is usually constant, at least for residential systems. What changes is the efficiency at which heat is transferred.
See if these help -
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/heatpump.html
http://www.aie.org.au/melb/material/resource/cop.htm
http://ist-socrates.berkeley.edu/~phy7b/solutions/T5_WkSheet/T5soln.html
http://electron9.phys.utk.edu/phys136d/modules/m3/heatpump.htm
  • · Replies 18 ·
9K
