Calculate Mg2+ & CO3 2- Concentration in Magnesium Carbonate Solution
The discussion revolves around calculating the concentrations of Mg2+ and CO32- in a saturated solution of magnesium carbonate (MgCO3) using its solubility product (Ksp). The conversation includes theoretical aspects, mathematical reasoning, and problem-solving strategies related to the topic.
  • Homework-related
  • One participant asks for help calculating the concentrations of Mg2+ and CO32- in a saturated solution, given the Ksp of MgCO3.
  • Another participant suggests starting with the expression for the solubility product and hints at the relationship between the concentrations of the ions.
  • A participant confirms the dissociation equation for MgCO3 and proposes the Ksp expression, noting that the concentrations of Mg2+ and CO32- will be equal.
  • There is a discussion about the implications of the Ksp expression and how it relates to the concentrations of the ions at equilibrium.
  • One participant expresses uncertainty about how to proceed with the calculations and seeks clarification on the next steps.
  • Another participant agrees with the approach and confirms that the concentration can be derived from the Ksp value.
  • One participant calculates the concentration of the ions and receives feedback on their arithmetic, with a correction provided.
  • There is a confirmation that the calculated concentration is consistent with the earlier derived expression.
Participants generally agree on the approach to solving the problem and the relationships between the ions' concentrations and the Ksp. However, there is some uncertainty regarding the arithmetic involved in the calculations.
Some participants express uncertainty about the application of the Ksp and the implications of the equilibrium state, indicating that the discussion may involve missing assumptions or unresolved steps in the calculation process.
egg
Hi need a bit of help with a question!
the solubility product of magnesium carbonate is 10^ -7.5. Calculate the concentration of Mg2+ and CO3 2- expected in a saturated solution assuming activity of both ions is 1.0
cheers in advance!
Can you start by writing an expression for the solubility product of [itex]MgCO_{3}[/itex]? I'll give you a hint as well;
What does this tell you about the relative concentrations of the [itex]Mg^{2+}[/itex] and [itex]CO_{3}^{2-}[/itex]. It may also helpful if you where to write out an equation of the dissociation of the ions.
~H
cheers for the reply hootenanny,
i wrote the initial question in a bit of a hurry yesterday and forgot to say i have NO idead what to do with the info!
I know the relative concentrations of the ions will be equal and think that the dissociation is
MgCO3 <=> Mg^2+ & CO3^2-
Think the expression you mean is Ksp=(aMg^2+)(aCO3^2-)/aMgCO3 but not too sure where to go now, do i replace the ions and the Ksp with the values i know and rearrange to find activity of MgCO3? if i do this what does it tell me?
This is a question in a past exam paper we've been given and I'm sure we weren't shown how to do it! My exams next week and this is the only question that's been causing us grief!
Yeah, this is correct. You are also correct with your Ksp expression;
[tex]K_{sp} = \frac{[Mg^{2+}][CO_{3}^{2-}]}{[MgCO_{3}]}[/tex]
This is something of a trick question really. The square brackets mean concentration of whatever is inside the square brackets. Now, as you correctly said in your equation, once dissociated the concentration of [itex]Mg^{2+}[/itex] and [itex]CO_{3}^{2-}[/itex] will be equal, so we can re-write the above Ksp expression as;
[tex]K_{sp} = \frac{[Mg^{2+}]^2}{[MgCO_{3}]}[/tex]
Do you follow this?
As [itex]MgCO_{3}[/itex] is only slightly soluble, once the above equation has reached equilibrium adding further solid will not cause any equilibrium shift as the solution is saturated. Therefore, the equation becomes;[tex]K_{sp} = [Mg^{2+}]^{2}[/tex]
Do you follow?
Now, consider how the concentration relates to the solubility product. What happens if the concentrations are greater, less than and equal to Ksp?~H
think I'm starting to understand a bit better now! can i now rearrange Ksp=[Mg^2+]^2 to
SQRT Ksp=[Mg^2+] or SQRT10^-7.5 in which case the concentration of the ions will be 10^-3.75 ??
Your logic is correct, but you might want to check your arithmetic, I get it to be 1.78x10-4 mol.dm-3
~H
yeah that's it, 1.78x10^-4 is the same as 10^-3.75! Thank you loads for the help, just need to revise a ton of other stuff for this exam!
Thanks again!
Thanks again!
O yeah, didn't spot that :rolleyes: No problem.
~H
  • · Replies 48 ·
10K
