Calculus of variations basic question
The discussion centers on the concept of first and second order deviations in the context of the calculus of variations, specifically relating to the path of least action as described in Feynman's Lectures II. The user seeks clarification on how deviations from a minimum value behave, particularly when the first derivative at that point is zero. The Taylor series expansion is utilized to illustrate that when the first derivative is zero, the deviation from the minimum is characterized as second order, meaning that small changes result in minimal first-order effects, thus confirming the properties of minima in functions.
  • Understanding of calculus, specifically derivatives and Taylor series.
  • Familiarity with the concept of minima in mathematical functions.
  • Knowledge of the calculus of variations and its applications.
  • Basic grasp of Feynman's Lectures on physics, particularly the path of least action.
  • Study the Taylor series expansion in more depth, focusing on its applications in calculus.
  • Explore the principles of the calculus of variations and its significance in physics.
  • Investigate the concept of minima and maxima in functions, including critical points.
  • Review Feynman's Lectures II for further insights into the path of least action and its mathematical implications.
Students of mathematics and physics, particularly those studying calculus and the calculus of variations, as well as educators seeking to clarify these concepts for their students.
alsey42147
this is one of those things that looks like it should be really simple but for some reason i just don't get it :confused: I've looked at a few books and they all start explaining calculus of variations in the same way.
i'll quote a paragraph from feynmann lectures II (concerning finding the path of least action) just to illustrate my problem:
"When we have a quantity which has a minimum - for instance, in an ordinary function like temperature - one of the properties of the minimum is that if we go away from the minimum in the first order, the deviation of the function from its minimum value is only second order. At any place else on the curve, if we move a small distance the value of the function changes also in the first order. But at a minimum, a tiny motion away makes, in the first approximation, no difference."
now, what is meant by first and second order in this context? i honestly don't get what is meant here. surely if you move away from the minimum of a function, the function changes according to itself. e.g. if f(x) = x^2, then if you move away from the minimum x=0 in the x-direction, f(x) changes by x^2. so what is meant by nothing changing in the first order?
Here is the Taylor series for the function f(x) about a point a.
f(x) = f(a) + f'(a)(x - a) + (1/2)f"(a)(x-a)^2 + ...
so the deviation is:
f(x) - f(a) = f'(a)(x - a) + (1/2)f"(a)(x-a)^2 + ...
(x-a) is the first order and therefor so is f'(a)(x - a)
(x-a)^2 is of second order and therefor so is (1/2)f"(a)(x-a)^2
The rest of the terms (denoted ...) are of third order and higher.
If f'(a) = 0 ( a property of the minimum), then
f(x) - f(a) = (1/2)f"(a)(x-a)^2 + ...
so the deviation is of second order.
thanks, that makes a lot more sense!
  • · Replies 36 ·
