Solving a Simple Math Equation for the Smallest Perimeter of a Rectangle
  • Thread starter Thread starter JayDub
The discussion revolves around finding the smallest perimeter of a rectangle given a fixed area of 64 cm². Participants are exploring the relationship between the dimensions of the rectangle and its perimeter.
  • Participants discuss the dimensions of the rectangle as x and 64/x, questioning how to effectively graph and analyze the perimeter. There is also a consideration of a related problem involving maximizing area with a fixed perimeter.
The conversation is active, with participants sharing their thoughts on graphing techniques and the implications of their findings. Some guidance has been offered regarding what to graph for minimizing perimeter, and there is an exploration of different approaches to the problem.
Participants are navigating the constraints of the problem, including the fixed area and the relationship between perimeter and dimensions. There is an acknowledgment of the need to clarify the correct function to graph for minimizing perimeter.
JayDub
I am trying to remember how I would go about solving an equation like so.
What is the smallest perimiter of a rectangle with area of 64 cm^2.
I know I can use the graphing calculator.
So I know there are two sides, x and 64 / x.
If I try and graph x(64/x) I just get a straight line at 64. So how does one go about solving a question like this?
Thank you.
Which is good -- you're graphing the area of your rectangle. It had better be a constant value!
Lol, I understand why it is giving me that (because the x's cancel) which I am sure you know.
If I had the inverse of this question, something like. The perimiter of a rectangle is 100 cm. What is the largest area it can have?
I would go
Side 1: x
Side 2: 50 - x
Graphing: x(50-x) thus at the maximum, x = 25.
Therby making the other side 25 as well, for a maximum area of 625 cm.
Well if you're trying to minimize perimeter in your original problem, what should you be graphing?
When looking for the rectangle with the largest area, why do you do those steps?
wait a minute... If
Side 1: x
Side 2: 64 / x
To find the smallest area couldn't I graph 2(x) + 2(64 / x) and find the smallest perimiter?
Thus graphing, gives me an x value of 8 and a perimiter of 32.
That sounds good.
  • · Replies 26 ·
