Magnetism, Orbits, Friction-Is there a relationship?
The discussion centers on the relationship between magnetism, planetary orbits, and the effects of friction in the context of celestial mechanics. Participants explore how planetary bodies, such as Earth, maintain their orbits over long periods without spiraling into the Sun, questioning the influence of magnetic fields and other forces on orbital dynamics.
  • Some participants question why Earth does not experience a decay in its orbit due to magnetic forces from the Sun, suggesting a potential "magnetic friction" that could affect its rotation and orbit.
  • Others argue that the initial angular momentum of the solar system is responsible for the planets' orbits, and that gravitational forces dominate over magnetic forces at the distances involved.
  • Mathematical relationships are discussed, including formulas for orbital velocity and radius, with some participants noting that a decrease in velocity would lead to an increase in orbital radius.
  • There is a suggestion that if the Earth were to stop moving, it would fall into the Sun, highlighting the importance of maintaining sufficient tangential velocity for stable orbits.
  • Some participants introduce the concept of the universe's expansion and question whether it could have any effect on the solar system, pondering if local gravity would counteract this effect.
  • Discussions include the conservation of angular momentum and the dynamics of elliptical orbits, with participants sharing equations related to orbital mechanics.
Participants express differing views on the significance of magnetic forces in planetary motion, with some asserting they are negligible while others speculate on their potential effects. The discussion on the expansion of the universe also reveals multiple competing perspectives, leaving the topic unresolved.
Some participants reference specific mathematical formulas and relationships without fully resolving the implications of these equations. The discussion also touches on assumptions regarding the effects of magnetic fields and the nature of gravitational interactions at large distances.
timejim
I hope this is the right Thread for this discussion. I was wondering by what actions do Planetary Bodies, such as the Earth, continue in their orbits, millenia after millenia and so on, without decaying and being "sucked" into the Sun, in a rather short period of Time. Something doesn't add up to me. If the Sun has "Magnetic" force radiating outwards from it in all directions, why, as the Earth orbits the Sun, does not its Rotation slow down, and its orbit Decay, as it moves thru this "field of magnetic attraction?". Wouldn't the surrounding "fields", as it interacts with the Earths magnetic field, create a sort of "Magnetic" friction? Would this not cause the Earths' roattion to slow? If not, why not? Likewise, would the Earths orbit be affected by the slowing of the Earths rotation from the friction induced by the magnetic field? If you pass 2 magnets close to each other they react in a physical way, i.e., moving, twisting, etc. Wouldn't this be the case with regards to the Earth traveling thru these radiated magnetic fields from the Sun? Just asking, it does interest me, though.
When the solar system fromed it had a significant amount of spinning motion, this motion was transferred to the planets as they formed. Thus the orbital motion of the planets is due to initial angular Momentum of the solar system.
Gravity is a weak but far reaching force, at the distances involved in the solar system magnetic forces are very small, thus have no significant effect on planetary motion.
If the Earth's rotation about the sun does slow it will not cause it to fall into the sun, just the opposite, a lower orbital velocity will mean that it must move to a orbit FURTHER from the sun.
Janus?
[tex]V_o = \sqrt{\frac{G M}{R}}[/tex]
If you arrange that to solve for R:
[tex]R = \frac{G M}{V^2}[/tex]
It would seem that if V decreases, R would increase. But the first formula is for determining the velocity one would need to maintain a circular orbit at a particular distance.
You would have to increase your velocity to reach a higher orbit and then decelerate to the new orbital velocity depending on the height of the new orbit. * see http://users.commkey.net/Braeunig/space/orbmech.htm
If the Earth were to stop dead in its tracks, it would fall into the sun.
The forces involved in the interaction of the magnetic fields are not big enough to be relevant to the orbits of the planets. They lose strength quickly with distance.
edit: can't think and type at the same time.
This thread kind of makes me wonder of something else that I have thought about. What about the expansion of the universe? If the stretching of space is uniform, would it have an effect on smaller scales like the solar system? Say for instance, if the universe had doubled in size the last five billion years, wouldn't it have a similar effect on expanding the solar system? Or do you think local gravity would completely overcome this force?
Good thought. I wonder about this, too. If everything is expanding away, what about solar systems or even Galaxies. Eventually you would be alone in the Universe. Doesn't make sense to me, formulas or no formulas.
Actually, you would have to accelerate to match match the orbital velocity of the higher orbit.
Assuming you are moving from an orbit of radius R1 to an orbit of radius R2.
You increase your velocity at some point of orbit 1. This will put you in a new orbit. This new orbit will be an eliptical one, with its perhelion (closest distance to the Sun) being at orbit 1 and its aphelion(furthest distance to the Sun) being at orbit 2.
Essentially, any change in velocity you make at an particular point of an orbit does not effect the orbit at that point but changes the orbital distance of the point 180° away.
At perhelion, it will will be traveling much faster (by the amount of the added velocity) than the orbital velocity of orbit 1.
As it climbs out to aphelion it will lose velocity such that by the time it reaches orbit 2, it will be traveling much slower than orbital velocity of orbit 2.
At which point you would accelerate to add velocity to match orbit 2. (By adding velocity at aphelion you increase the distance of perheion. Increase it enough, and you raise the perhelion to the same distance as aphelion and you get a circular orbit. )
One formula for determining the velocity at aphelion of an eliptical orbit is
[tex]V_{a}= \sqrt{\frac{2GM}{(R_{p}+R_{a})}\frac{R_{p}}{R_{a}}}[/tex]
[tex]R_{a}[/tex] is the distance of the aphelion
and
[tex]R_{p}[/tex] is the distance of the perhelion
To get the velocity at perhelion, just transpose the values for perhelion distance and aphelion distance in the formula.
The formula for determining how much velocity you need to add to orbit 1 in order to enter the eliptical orbit needed to reach orbit 2 is
[tex]\Delta V = V_{R_{2}}\left[ \sqrt{\frac{2R_{1}}{R_{1}+R_{2}}}-1 \right][/tex]
[tex]V_{R_{1}}[/tex] is the orbital velocity of orbit 1.
and
[tex]\Delta V = V_{R_{1}}\left[ \sqrt{\frac{2R_{1}}{R_{1}+R_{2}}}-1 \right][/tex]
How do you get to these equations?
edit:
Oh wait, you have m*ra*va=m*rp*vp because angular momentum is conserved, and 1/2mva^2+-GMm/ra=1/2mvp^2+-GMm/rp and you just solve these two equations for what you want. Is this right?
Thanks for that correction Janus. You made it very easy to understand. I guess that's why you're a mentor, eh? :smile: I'll definitely study those formulas.
Given that space junk in insufficiently high orbit eventaully comes crashing to earth, your comments surprise me.
yeah, he's mistaken. At distance r, the Earth always accelerate towards the sun at the same rate. If it is moving sufficiently fast(tengentially), sqrt(GM/r), the acceleration will only make it stay in orbit. However, if it is slower, it will fall into the sun. (centrifugal force not strong enough to cancel the sun's attraction, if you look at it along the Earth to sun |distance| axis)
Well, everyone makes mistakes from time to time.
Actually, whether the Earth would fall into the sun depends on how much the velocity decreased. It could just fall into an orbit with a higher eccentricity if the change in V was small enough.
Correct. In fact, the Earth would have to lose about 99% of its present orbital velocity of 30km/sec in order to hit the Sun.
This means it would take a greater velocity change (and thus energy expended) to cause the Earth to fall into the Sun than it would take to throw the Earth completely free of the Solar System. (about 41% of its present orbital velocity.)
Surprisingly enough, that's atmospheric drag! In space!
Cool, thanks for precising that! Sounds logical, as long as the orbit has a perigee higher than the sun's radius, it should not fall into the sun. (It'd probably get a bit too hot for comfort though :wink: )
Thanks Janus. I wasn't sure about the exact numbers. In fact, I was going to asked what the maximum change in velocity would need to be for the Earth to fall into the sun.
Gee, I'm not sure which fate would be worse.
Simple solution
These I like best. Simple solutions to questions.
Check out http://www.geocities.com/terella1/ regarding planets and magnetism. Fact is that magnetic fields do not rotate with the planet.
May sound silly. But ... Just check it out!
  • · Replies 44 ·
