| Thread Closed |
Adiabatic Processes and Ideal Gases |
Share Thread | Thread Tools |
| May18-06, 07:31 AM | #1 |
Hey.
Im doing this question where Air (said to be ideal gas) is compressed from a pressure of 0.1 MPa and Temp 300K to pressure .5 MPa and temperature 480K. We are supposed to determine whether the process is possible to do adiabatically (sorry if that is the wrong spelling). I hadnt done a question like this before so i began by assuming it was an adiabatic process. by doing this and using thermodynamic data from Moran and Shapiro (our text book) i got the work done on the system to be approx. 130 kJ/kg I then went on to try and use the ideal gas equation to determine the work required for this process (using the definition, work = integral (pressure) dV) now, to do this i had to make the assumption that for an ideal gas an Adiabatic process is also polytropic (pV^n = const.) My notes say that polytropic processes do not have to be adiabatic, but it does not describe whether or not adiabatic processes have to be polytropic (my assumption). My question is, If a process is adiabatic, does it mean it is also polytropic? PS. Using my above method i get a rather nice answer, being that it is not possible, but i do not enjoying making assumptions. cheers, bart |
| May18-06, 09:36 AM | #2 |
Why do you need to find the work done?
An adiabatic process is one in which no heat is gained or lost by the system (ie, Q=0). So, just apply the definition here. Isn't this question very straight-forward? |
| May18-06, 07:08 PM | #3 |
when you apply the definition and the enrgy balance equation all you can calculate is the work. i understand what an adiabatic process is, but i was unsure how to determine whether it is possible for this process so i began by looking at how the process being adiabatic might affect it.
i apologise, maybe i was not clear but we are supposed to determine if it is possible to do adiabatically. maybe a better question is why wouldnt this process be possible to do adiabatically. we are covering the second law of thermodynamics at the moment, but all my notes on the topic are for cycles, which this is not. so im am not sure how it may be applied here. cheers, bart |
| May18-06, 11:05 PM | #4 |
Recognitions:
Adiabatic Processes and Ideal Gases[tex]PV^\gamma = \text{constant}[/tex] applies. In the case of the adiabatic process, [itex]n = \gamma = C_p/C_v[/itex]. So, find out the value of [itex]\gamma[/itex] for air and see if the relation applies. AM |
| May19-06, 12:11 AM | #5 |
If you are specifically trying to see if the process can be both reversible and adiabatic, remember that the change in entropy in a reversible adiabatic process is 0. So, calculate the change in entropy between the two states. If it's non zero, then the process can't be reversible adaibatic. |
| May19-06, 08:28 AM | #6 |
Recognitions:
Since PV=nRT and [tex]PV^\gamma = K[/tex] [tex]V = (KP)^{-1/\gamma} = nRTP^{-1}[/tex] So in terms of temperature and pressure: [tex]TP^{1/\gamma - 1} = \text{constant}[/tex] Plugging in the values given and : [tex]300 * .1^{-.286} = 580 \approx 480 * .5^{-.286} = 585 [/tex] So the answer should be yes. AM |
| May19-06, 11:54 AM | #7 |
| May19-06, 03:09 PM | #8 |
Recognitions:
So I am having difficulty seeing how you could have an adiabatic compression (ie without exchanging heat with the surroundings) without it being fully resisted. Can you give an example? AM |
| May19-06, 10:30 PM | #9 |
Ok. Let's say you have a completely insulated tank, filled with air at some low pressure. On the top is a movable and insulated piston open to the atomsphere which is at a higher pressure than the air inside. There is a latch present which prevents the piston from falling initially. When the latch is removed, the piston will fall and I think the resulting process will be an irreversible adiabatic process, which won't be fully resisted. |
| May20-06, 12:01 AM | #10 |
Recognitions:
The energy of the resulting oscillating compression wave inside the gas eventually dissipates as heat. So, again, there is effectively heat added to the gas. In my view, one could argue that such a process is non-adiabatic. The whole problem is one of defining 'adiabatic'. In my view, the term 'adiabatic' should be used only to reversible processes because 'adiabatic non-reversible' processes effectively transfer additional heat to the gas. AM |
| May20-06, 08:40 AM | #11 |
what i did in the end for this question was look at the entropy change in going from state 1 to state 2.
this turned out to be negative. i then looked at the formula for a closed system; s2-s1 = integral (delta Q x 1/T) + entropy production for an adiabatic process, integral (delta Q x 1/T) = 0, this would mean that the entropy production would be less than zero which is not possible. from this i concluded the process is not able to be done adiabatically. now, i had to assume it was a closed system which i believe is a fair assumption. does that seem ok? |
| May20-06, 11:35 AM | #12 |
Recognitions:
AM |
| May20-06, 09:53 PM | #13 |
Recognitions:
Since ds = dQ/T and dQ = dU + dW where dW is the work done by the gas: (1)[tex]\Delta S = \int_{T_{i}}^{T_{f}} dQ/T = \int_{T_{i}}^{T_{f}} dU/T + \int_{T_{i}}^{T_{f}} dW/T[/tex] Since d(PV) = PdV + VdP = nRdT and dW = PdV, dW = nRdT - VdP = nRdT - nRTdP/P [tex]dS = dQ/T = (dU + dW)/T = nC_vdT/T + nRdT/T - nRdP/P = nC_pdT/T - nRdP/P[/tex] [tex]\Delta S = \int_{T_{i}}^{T_{f}} dS = nC_p\int_{T_{i}}^{T_{f}} dT/T - nR\int_{P_{i}}^{P_{f}} dP/P[/tex] [tex]\Delta S = nC_p\ln\left(\frac{T_f}{T_i}\right) - nR\ln\left(\frac{P_f}{P_i}\right)[/tex] C_p for air is: 3.5R In this case: [tex]\Delta S = nR(3.5*\ln(480/300) - \ln(.5/.1)) = nR(1.6-1.6) = 0[/tex] AM |
| May21-06, 12:06 AM | #14 |
Yeah Andrew, that's perfectly right.
I understand what you say about it being practically not possible to achieve a adiabatic compression process, which isn't fully resisted. |
| May21-06, 09:23 AM | #15 |
Im doing Thermodynamics as part of an engineering course so its more equatoins and tables of thermodynamical data (this leaves me feeling rather empty, thus i try to understand the origins of the equations as much as i can).
I just found a mistake in one of my calculations because some of my units were in kJ/kgK and some were in J/kgK revised, i use the equation; s2-s1 = s0(T2)-s0(T1)-Rln(p2/p1) = 2.17760-1.70203-(8.314/28.97)ln(0.5/0.1) = 0.01368 kJ/kgK By the procedure i was using before, this means that entropy production would be greater than 0 and the process possible. Though i wonder how the entropy production occurs. I got the s0 values from a table and used that to calculate the entropy change (the s0 values are just difficult to calculate integrals that were determined experimentally). Im not sure you guys would have the same text book we use here, but it was Fundamentals of Engineering Thermodynamics by Moran and Shapiro table A-22 The reason i look at entropy production is because the question does not say the process has to be reversible. it simply asks if it is possible to be done adiabatically. Thats why i thought i should show that for the process to be adiabatic entropy production was greater than or equal to 0. Otherwise i dont think the solution would have been complete. |
| May21-06, 10:06 AM | #16 |
Recognitions:
In any event, since the adiabatic condition, [itex]P_iV_i^\gamma = K = P_fV_f^\gamma[/itex] applies to within significant figures, it can be done adiabatically and reversibly. Entropy change is also 0 to within significant figures which also means it is adiabatic. I should also point out that an entropy change of a system can be negative. It is the entropy of the system and its surroundings (universe) that cannot decrease. In this case, you do not have a closed system. The gas can is being compressed due to work supplied from its surroundings. In the example discussed above by siddharth of a piston dropping and compressing a gas, the gas could have a negative entropy change. AM |
| May22-06, 03:11 AM | #17 |
We are taught what is probably not standard notation. But in the equations i have been given R is not the universal gas constant, rather it is the gas constant for the gas. This is the universal gas constant divided by the molar mass of the gas.
In this case R= (8.314 kJ/kmol K) / (28.97 kg/kmol) - i accidently forgot to remove the x10^3 when iedited it, sorry The values in my previous post are all for kJ and kg, and as i said, i still get a positive number, not zero or even one that rounds to zero. You didnt say if you found the same textbook i was using, but if you did i am using Equation 6.21a in chapter 6. In regards to your last point, i do realise that entropy change of the system does not need be positive in general, BUT, in this case, where we also have the definition for entropy change as; s2-s1 = integral (ds/T) + entropy production simplifying (with ds=0) to; s2-s1 = entropy production surely entropy change has to be greater than or equal to 0, otherwise it implies negative entropy production which (according to the countless reminders all through all my texts and notes) is not possible. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Adiabatic Processes and Ideal Gases
| heat and adiabatic processes perhaps | Introductory Physics Homework | 2 | ||
| Adiabatic Processes | Introductory Physics Homework | 1 | ||
| Adiabatic Processes | Introductory Physics Homework | 2 | ||
| Adiabatic Processes (cylinder) | Introductory Physics Homework | 7 | ||
| Adiabatic Processes in the Carnot Cycle | Classical Physics | 2 | ||
