How Do You Convert 290mcd to Candelas/Meter Square?
  • Context: Undergrad
  • Thread starter Thread starter alexa179
    Luminosity
The conversion from 290 milicandelas (mcd) to candelas per meter square (cd/m²) is not directly possible without additional information. To compute luminance (E) in cd/m² from luminous intensity (I) in candelas, one must use the formula E = I / (r²) cos(α), where 'r' is the distance from the light source to the point of measurement and 'α' is the angle of incidence. This formula is essential for understanding how luminous intensity relates to luminance on a surface.
  • Understanding of luminous intensity (candela)
  • Knowledge of luminance (candelas per meter square)
  • Familiarity with geometric relationships in lighting
  • Basic trigonometry for angle calculations
  • Study the formula for luminance calculation in lighting design
  • Learn about the relationship between luminous intensity and distance
  • Explore practical applications of luminance in interior lighting
  • Research the impact of angle of incidence on light measurement
Lighting designers, electrical engineers, and anyone involved in photometry or lighting calculations will benefit from this discussion.
alexa179
Could someone help me out with a conversion question.
How do you convert 290mcd to candelas/meter square?
Or what additional information do I need to make the converstion?
Thanks!
Science news on Phys.org
If "mcd" means milicandela then a "conversion" between these two quantities is impossible. I think you have to compute the luminance E (in cd/m^2) at a given point on a surface from a source with a given luminous intensity I (in cd). If this is the case, the equation you need is
[tex]E=\frac{I}{r^2}cos \alpha[/tex]
with r the distance from the source to the point and \alpha the incidence angle (measured from the normal direction).
  • · Replies 17 ·
  • · Replies 17 ·
