Thread Closed
Infinite Line Charges
Share Thread Thread Tools
May18-06, 04:21 PM   #1
Hi there, this is my first post and I hope you don't mind helping me out a bit because I'm really stuck. I'm doing computer science in university and the electrotechnology part can be a bit tricky for us.
For an infinite line charge Pl = (10^-9)/2 C/m on the z axis, find the potential difference points a and b at distances 2m and 4m respectively along the x axis.
I have a basic understanding of physics, Coloumb's Law, Voltage etc... but I don't know about this infinite line charge stuff. I'm not looking for a solution, I actually have the answer here (it's 6.24v in case you're interested) but I'd like to know how to calculate it. If this wasn't a line charge, i.e. if this was a point charge at the origin, I would be able to do it.
Thanks in advance
Edit: I noticed in the FAQ it said I should show my attempts. The thing is, I know how to finish it, just not how to begin it.
So if I were to go about this, I would get the potential of each point using this formula:
q/(4)(pi)(eps)(r). I derived that from integrating Coloumb's Law with respect to r. I'd then subtract point b from point a to get the voltage.
Coloumb's law wouldn't appear to work here though because it's a line charge and not a point charge. This is my attempt, I hope it's not too pathetic.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May18-06, 05:33 PM   #2
I see this is being done for a computer science class, are you attempting to calculate the potential from an infinite line of charge by summing up an large number of point charges, as you might do in a computer approximation? Or are you attempting to do an integral and find the algebraic answer?
I'm guessing you are talking about the algebraic answer:
You have an algebraic answer for the potential from a point charge correct?
[tex] V(r) = \frac{1}{4 \pi \epsilon_0}\frac{q}{r} [/tex]
where r is the distance from the charge to your point:
Now what you want to do is sum up an infinite number of these small charges, the force law is the same, but your distance will change as you move down the wire. If you are integrating down the z axis from 0 to infinity, try to think of a way to write a Coloumb's law expression for any arbitrary point on the wire z distance from the origin. Then you can integrate over all the possible z's.
~Lyuokdea
May18-06, 05:56 PM   #3
Lyuokdea, thanks so much for your help! This really clears up a few things in my head.
Maybe you could just give me one or two more hints though. Essentially what I'm trying to get the potential due to the point charge at R to R+infinite and R to R-infinite. I would imagine integration would be a good way to do this, but I can't see a way to write that. Hmmm
May18-06, 07:05 PM   #4
[tex] V(r) = \frac{q}{4 \pi \epsilon_0} \int^r_\infty \frac{1}{r}[/tex]
This is what I thought of, but it doesn't help because essentially it yields:
[tex]\ln\frac{r}{\infty} = \ln0[/tex]
which is undefined. :<
May18-06, 07:06 PM   #5
Recognitions:
Homework Helper Homework Help
Quote by exiztone
I can guide you through it but I first want to make sure that I am doing it at the right level.
There are three approaches possible:
a) There is a formula for th potential due to an infinite line of charge. If you have seen it in class and you are allowed to use it, the calculation is just two lines. I don't want to make you do an integral if you are allowed to use the formula!
b) At a more fundamental level, one can actually prove the formula mentioned above using calculus. Do you think this is what you are expected to do? Are you at ease with simple integrals?
c) it can also be done purely numerically as Lyuokdea mentioned.
So what is expected of you, do you think?
Patrick
May18-06, 07:15 PM   #6
Hi Patrick:
I sincerely don't know what we're allowed to use. I would like to see the integral method for my own understanding, but if there is an easier way, I would probably use that in the exam (I am just trying to understand the concepts right now).
As for proof. I think we just have to arrive at the correct answer after calculating it somehow. I don't think we have to worry about proving formulae, just be able to use them and understand what they do.
I apologise that I'm very hazy about this. The whole class is on the same boat since we signed up for computer science and this electrotechnology is a little out of our league. We're scared of the lecturer so nobody asks questions. Also, the person who is supposed to help us with these problems wasn't able to.
May18-06, 07:22 PM   #7
Recognitions:
Quote by exiztone
Hi Patrick:
Ah, yes, the scary lecturer I also try to be as scary as possible when I teach...saves a lot of questions
There *is* a simple formula that could be used to solve in two lines. But if this was the way to go, you would have seen it in class (I assume). In any case, we'll prove it since you know calculus.
Let's say that the line of charge is on the x axis, from -infinity to plus infinity. Let's say that we want to find the potential at a point P=(0,y), that is at a distance y above the origin.
Now consider a small piece of the line of charge of length dx located somewhere to the left of the origin. It contains a small charge dq.
So, to be clear, this small dq is located at a position (-x, 0). Ok?
What is the distance r between this small dq and the point P, in terms of x and y? (that's just Pythagora's theorem) That will be what we will use for "r" in the integral.
May18-06, 07:37 PM   #8
Patrick, thanks, this makes a lot of sense!
Would it be something like this then?
[tex] \frac{q}{4 \pi \epsilon_0} \int^1_\infty \frac{1}{\sqrt{r^2 + n^2}}DN[/tex]
Thanks very much for the help! I think I'm getting on the right track now :)
Edit: I can't seem to get it right in Latex but that should be -infinite and +infinite for the definite integral.
May18-06, 07:49 PM   #9
Recognitions:
Quote by exiztone
Well, I am more used to see x and y used instead or r and n!
But you almost have it exceot for one thing:
where does your DN come from? (what I would call dx)
You cannot put it by hand like this with no justification.
To be exact, you should have
[tex] \int_{-\infty}^{\infty} { dq \over {\sqrt{x^2 + y^2}}} [/tex]
where y is a constant kept fixed (so we could call it "r", the perpendicular distance between the line and the point P).
The only step missing is to relate dq to dx. You know how to do that?
May18-06, 08:00 PM   #10
Patrick: Now I am stuck again. I put in DN (DX) because I thought we have to integrate the formula with respect to X (since we're summing up an infinite amount of points on the X axis). I don't see where you got your DQ from though. And why would we want that as opposed to DX?
Sorry for being clueless on the matter, I'm familiar with integration, but I think this is the first time I've applied it to a real situation.
I don't think I know how to relate dq to dx, unless it's that substitution with U routine.
Thanks again! I'm really learning from this.
May18-06, 08:20 PM   #11
Recognitions:
Quote by exiztone
Sorry I forgot the 1/(4 pi epsilon_0).
I slowed you down because this is the most tricky (and important) point of the derivation. And I know by experience that this is always difficult for students applying calculus to physics for the first time.
The key point is that the potential of a point charge is
q/(4 pi epsilon_0 r)
right?
Now, your small dq located at (-x,o) is a point charge, so the potential it produces at the point P (0,y) is simply
[tex] { 1 \over 4 \pi \epsilon_0} { dq \over {\sqrt{x^2 + y^2}} } [/tex]
This is *it*!! Just think of dq as being a point charge q...there is nothing else to add!!
Now, the problem is that before you can integrate, you must express all the variables in terms of a single variable. What varies here is "x" (as you sum over all the small pieces of the line of charge) so you want to relate the infinitesimal dq to an infinitesimal dx.
The key point is that dq is, by definition, the small charge contained in a small piece of length dx. Therefore, [itex] dq = \lambda dx [/itex] where lambda is the linear charge density. Now you are ready to integrate because you have
[tex] {1 \over 4 \pi \epsilon_0} \int_{- \infty}^{\infty} \, \lambda dx \, {1 \over {\sqrt{x^2 +y^2}} } [/tex]
Here, y and lambda are constants. So you are all set, you just have to integrate this. we have done most of the work, which is to get from the physical situation to an integral to calculate. Now it is like pure maths, you just have to integrate this (should make you think about arctan, btw).
I hope this makes sense.
Patrick
May18-06, 08:34 PM   #12
Hi Patrick,
Thanks for such a lengthy reply. Once again it's very strange because some of these ideas were never introduced to us in class and now I feel a little angry because of that.
I'd like to ask you about two things, namely the dq and the lambda.
You see, I don't understand why we have this dq when the infinite line charge is equal, there's [tex] {10^{-9}\over 2} C/m [/tex] which is a constant. Also, the above equation has no Q in it so how do I insert the size of the charge?
And this lambda, what do I do with it? Is there an absolute value for it? How do I get rid of it to get my potential, or does it disappear when we subtract F(b) from F(a)?
Thanks for your help!
May18-06, 08:41 PM   #13
Recognitions:
Quote by exiztone
Hi Patrick,
*This* is your lambda! Notice the units: coulomb per meter. What is the meaning of this quantity? Consider the following question: if you take a piece of the line of charge which is, let's say, 80 cm long. How much charge does it contain? The answer is: multiply the length by lambda! So here, you would multiply 0.80 meter with your lambda and get an answer in Coulomb, which represents the amount of charge contained in a section 0.80 m long.
So, the amount of charge contained in a small piece of length dx is equal to dx times lambda. Since this is a tiny charge, we use the symbol dq instead of q. So dq= lambda dx
It's the value you gave above. And no, it won't disappear at the end. It will be needed to get your numerical answer at the end.
Hope this makes sense.
It is kind of crazy to have you do a problem like this without having explained those concepts!
PAtrick
May18-06, 09:11 PM   #14
Hi Patrick, thank you very much. All that makes perfect sense now. You are very kind to explain it all to me!
I have to say, that integration at the end is rather complicated.
I've heard for integrating that format you use
[tex]\ln{|{x + \sqrt{y^2 + x^2}\over y}|}[/tex]
This is very complicated to calculate, especially with infinites involed. Might you suggest an easier approach to integrate such a formula?
Thanks!
May18-06, 09:20 PM   #15
Recognitions:
Quote by exiztone
[tex]\ln\pmod{x + \sqrt{y^2 + x^2}\over y}[/tex]
Thanks!
[tex] \int {dx \over {\sqr{ x^2 + y^2} }} = \int {dx \over y} {1 \over {\sqrt{ 1 + (x^2/y^2)}}} = \int { dz \over {\sqrt{ 1 + z^2}}} [/tex]
where z is defined to be x/y (and the limits are -infinity to +infinity in all the integrals).
This last integral is a standard one. If you have a table of integral, it will surely be listed.
Patrick
May18-06, 09:31 PM   #16
My tables book doesn't have anything like that, I'm sorry. I have a special one for the Irish education system.
I know this is slightly cheeky, but do you think you could perform the integration on one of the numbers (say the point charge at 2m), I'm really having trouble with it.
Thanks a million!
May19-06, 07:17 AM   #17
Patrick, or anyone else who might be able to help.
After many attempts I got the following:
[tex][\sinh^{-1} ({\frac{x}{2}})]^{+\infty}_{-\infty}[/tex]
But I can't go on from there. I have to get rid of the infinite somehow, but I can't see how. Can you point me in the right direction? Thank you so much!
Thread Closed
Thread Tools
Similar Threads for: Infinite Line Charges
Thread Forum Replies
why potential of an infinite line of charge not equals to zero at r = infinite General Physics 17
three charges in a line (need help fast --please? (thanks)) Introductory Physics Homework 1
Electrostatics - line charges Introductory Physics Homework 2
Point charges on a line Introductory Physics Homework 2
Electric field from infinite charges Introductory Physics Homework 6
