Why electric charge is attracted to the earth (ground) ?
The discussion centers on the reasons why electric charge is attracted to the Earth (ground), exploring concepts related to charge density, conductivity, and potential difference. The scope includes theoretical explanations and analogies related to electrical behavior.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant suggests that the low charge-density of the Earth causes charge to flow from regions of high charge-density to low charge-density, drawing an analogy to air pressure.
  • Another participant states that excess charge is attracted to any conductor, implying that if the Earth were a good insulator, it would not attract charge.
  • This participant also notes that excess charge will flow onto an object until a potential difference builds up, comparing it to pumping air into a tank, where the flow stops once pressure rises significantly.
  • They further argue that because the Earth is very large, it can accept a significant amount of charge without a noticeable increase in electrical potential.
Participants present multiple viewpoints regarding the attraction of electric charge to the Earth, with no consensus reached on a singular explanation. The discussion reflects differing perspectives on the roles of charge density, conductivity, and potential difference.
Some assumptions about the nature of charge flow and the properties of the Earth as a conductor versus an insulator are not fully explored, leaving room for further clarification.
username
Anybody know why electric charge is attracted to the Earth (ground) ?
Because the charge-density of the Earth is very low and charge flows from regions with a high charge-density to regions with a low one. Just compare it to air-pressure.
Two answers:
1. Excess charge is always attracted to any conductor. If the Earth in your area was a good insulator, it would NOT attract charge.
2. Excess charge will only flow onto an object until a potential difference builds up and halts the flow. It's vaguely like pumping air into a tank: eventually the pressure will rise and stall the pump. If the object in question is REALLY LARGE, how much charge do you have to pump onto it before the electrical potential rises significantly? Lots and lots. You can dump huge amounts of charge into the earth, yet it still behaves as if it's uncharged.
Thanks for the explanation and clearing that up.
  • · Replies 58 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 16 ·
