Merry go round with a moment of inertia
The discussion centers on calculating the new angular velocity of a merry-go-round after an 80-kg man steps onto it. The initial moment of inertia is 1000 kg m², and the initial angular velocity is 2.20 rad/s. The principle of conservation of angular momentum is applied, requiring the calculation of the combined moment of inertia for the system after the man steps on. The final angular velocity can be determined using the equation for angular momentum before and after the man steps onto the merry-go-round.
  • Understanding of angular momentum conservation
  • Familiarity with moment of inertia calculations
  • Basic knowledge of rotational dynamics
  • Ability to solve equations involving angular velocity
  • Calculate the moment of inertia for the "merry-go-round + man" system
  • Apply the conservation of angular momentum to find the final angular velocity
  • Review rotational dynamics principles in physics
  • Explore real-world applications of angular momentum in mechanical systems
Students studying physics, particularly those focusing on rotational dynamics, as well as educators and anyone interested in practical applications of angular momentum principles.
phy21050
Would someone work through a step by step solution...Thank you. A merry go round with a moment of inertia of 1000kgm^2 is coasting at 2,20 rad/s. When a 80-kg man steps onto the rim, a distance of 2m from the axisof rotation the angular velocity decreases to ? rad/s
Originally posted by phy21050
Would someone work through a step by step solution...Thank you. A merry go round with a moment of inertia of 1000 kg m^2 is coasting at 2,20 rad/s. When a 80-kg man steps onto the rim, a distance of 2m from the axis of rotation the angular velocity decreases to ? rad/s
You know that the total angular momentum is constant correct? Well write it out.
Write an expression for the total angular momentum of the merry go round before the man stepped on it. After the man steps on it then once more write an expression for total angular momentum. Then solve for the final angular momentum.
Hint - you're going to need to fine the moment of inertia for the "merry-go-round + man" system.
Give it a try and then we'll go from where you get confused - post the equations that you go to up until you get stuck. Good luck!
Pete
  • · Replies 30 ·
28K
  • · Replies 138 ·
9K
