Is the Electric Field at Point (-1,0) Correctly Calculated?
The electric field at point (-1,0) due to two charges, (-3*10^-6)C at the origin and (6*10^-6)C at (2,0), was calculated to be Etotal = (-2.09*10^4) N/C. The calculation involved summing the contributions from both charges using the formula Etotal = Eq1 + Eq2, where Eq1 = k(q1)/r^2 and Eq2 = k(q2)/(2-r)^2. Despite the negative result, the direction of the electric field indicates it is positive, as it reflects the force on a unit positive charge.
  • Understanding of Coulomb's Law
  • Familiarity with electric field calculations
  • Knowledge of vector addition in physics
  • Basic proficiency in using online physics tools like HyperPhysics
  • Review Coulomb's Law and its application in electric field calculations
  • Learn about vector fields and their directionality in electrostatics
  • Explore the use of simulation tools for visualizing electric fields
  • Investigate common pitfalls in electric field calculations and how to avoid them
Students in physics, educators teaching electrostatics, and anyone interested in understanding electric field calculations and their implications in real-world scenarios.
nyclio
Two charges located along the x-axis, (-3*10^-6)C at the origin, and (6*10^-6)C at the point (2,0)
What is the electric field at point -1,0?
i did:
Etotal = Eq1+Eq2
=(k(q1)/r^2) + (k(q2)/(2-r)^2)
=(-2.09*10^4) N/C
Can someone please double check my calculations (i did it a few different ways and i always end up with a negative answer)? I plugged this into http://hyperphysics.phy-astr.gsu.edu/hbase/electric/e2p.html#c1 and for some reason their answer comes out positive. Which one is correct?
i did:
Etotal = Eq1+Eq2
=(-2.09*10^4) N/C
The direction of the field is given by the direction of the force on a unit positive charge (ie. of +1C. ). [itex]\vec E = \vec F/q[/itex]. So, in this case the field is positive.
AM
  • · Replies 16 ·
