New Reply
need help understanding the transistor circuit of an Boolean "NOT gate"
Share Thread Thread Tools
May22-06, 06:15 AM   #1
can some one plz link or upload a scheme or would this one i attached work? and how do you display in which direction the current flows? thats what i'm trying to show with the battery halves...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun13-06, 10:44 AM   #2
Mentor
No, what you have drawn will not work as an inverter. Just look at the simplified schematic of some inverter gates in their datasheets:
74S04 -- http://rocky.digikey.com/scripts/Pro...296&M=SN74S04N
74HCU04 (unbuffered inverter) -- http://rocky.digikey.com/scripts/Pro...6&M=SN74HCU04N
Aug10-11, 10:31 AM   #3
What I believe is: you want to let the transistor act like an inverter.
The circuit you attached won't work because:
1 - you must put a resistor Rb on the base of the transistor.
2 - when the input is logic 0, the transistor is turned ON and it will behaves like a wire, therefore , a short is gonna happen because the ON state transistor will short the 6V to ground.
I attached a circuit that will work properly... and here you are:
As you can see, there are 2 resistors in this circuit: Rc and Rb...
Rc is put so there will be no short circuit when the transistor is ON.
Rb is put to limit the base current ib.
This circuit will work properly as a Boolean "NOT Gate"
The logic 1 input signal will turn the transistor ON, so it will act like a wire, and the output is shorted to the ground, which means the output is logic 0.
And vice versa, when the input signal is logic 0, the transistor turns OFF, and there will be no current passing through the resistor, therefore the whole +Vs voltage will drop between the collector and the ground as output voltage, so the output voltage is logic 1 now !
As a summary, when the input signal is logic 1 , the output signal is logic 0...but when the input voltage is logic 0 , the output voltage is logic 1...so the circuit is acting just like a "NOT GATE" !
I hope this helps...
Aug10-11, 03:49 PM   #4
I forgot about the current...
When the transistor is on (i.e. the input signal is logic 1) the current will pass from the +Vs to ground, in other words from the collector toward the emitter.
But when the transistor in off (i.e. the input signal is logic 0) no current will flow through the transistor because it's OFF.
If the output signal is applied to a load (e.g. Resistor RL) the current will flow from +Vs through Rc and then through the load RL to the ground.
New Reply
Thread Tools
Similar Threads for: need help understanding the transistor circuit of an Boolean "NOT gate"
Thread Forum Replies
Problem understanding "Thévenins equivalent circuit " Engineering, Comp Sci, & Technology Homework 1
Current Electricity: Help understanding concept of "potential energy" Introductory Physics Homework 18
DRAFT paper "Why Local Duality Symmetry May be the Key to Understanding Fermion Generation Replication and Rest Masses", comments appreciated General Physics 0
understanding differential equations "backwards" Differential Equations 15
