If 0 = 1, does this mean that 0 = 1?
  • Context: High School
  • Thread starter Thread starter James_fl
    Mean
The discussion revolves around the implications of the statement "If 0 = 1, does this mean that 0 = 1?" Participants explore the nature of the factorial function, particularly focusing on the injectivity of the function and the definitions of factorial values, such as 0! and 1!. The conversation includes mathematical reasoning, conceptual clarifications, and some debate over the properties of functions.
  • Some participants assert that 0! = 1 by definition, questioning the implications of this definition.
  • Others argue that the factorial function is not injective, citing examples where different inputs yield the same output, such as 0! = 1!.
  • A participant proposes that if 5! = x!, then x must equal 5, but others challenge this by stating that it does not hold for all cases.
  • There is a discussion about the nature of injective functions, with some participants expressing confusion over the definition and implications of injectivity.
  • Some participants suggest that demonstrating a single case does not constitute a proof for all cases, emphasizing the need for generalization in mathematical arguments.
  • One participant expresses a desire to understand the concept better, indicating that they are a high school student and seeking clarification on the topic.
Participants do not reach a consensus on the injectivity of the factorial function. While some agree that the function is not injective due to specific counterexamples, others express confusion and seek clarification on the definitions and implications of injectivity.
Limitations in the discussion include varying levels of mathematical knowledge among participants, leading to misunderstandings about the properties of functions and the definitions of factorial values. The discussion also reflects uncertainty regarding the generalization of specific cases to broader mathematical principles.
This discussion may be useful for students or individuals interested in understanding the properties of mathematical functions, particularly factorials, and the concept of injectivity in mathematics.
James_fl
Well obviously, no is the answer. But why?
After all: If 5! = x! then x = 5.
Mathematics news on Phys.org
let me define a function f(x) = 5
since f(5) = f(8), does that mean 5=8?
No, because the 5 in f(x) = 5 is a constant.
Does this have something to do with the fact that the value 0!=1 and 1!=1 are defined; and hence they are constants?
If so, how should I put it down to words?
The reason we define 0! to be equal to 1 is due to the combinatorial interpretation of the factorial function. This interpretation says the number of ways to arrange n objects is n! So there is exactly 1 way to arrange 0 objects, and there is also exactly 1 way to arrange 1 object (and 2 ways for 2 objects, etc.)
0!=1 by definition, yes.
Ok, if you don't accept that argument, then what about sin? If sin(x)=sin(y) does that mean x=y? Of course not (0, pi, 2pi, 3pi, etc..). Functions were we can say f(x)=f(y) implies x=y are called injective (or one-to-one) and it has nothing to do with 'constants' at all. It so happens that the factorial function is not injective.
James, there is no "inverse" factorial function that would return a when applied to a! as far as I know.
Take your equation:
0!=1!
What would you do to both sides to get 0=1?
(Now you might say that since sin has an invese function that sin(x)=sin(y) would imply that x=y if you took the arcsin of both sides, but remember that arcsin has a range of −π/2 ≤ y ≤ π/2 so all that you'll prove is that some value between -pi/2 and pi/2 is equal to itself.)
matt grime: if factorial function is not injective, then why is it that i can show by inspection: if 5! = x!, then x=5? My Math knowledge is limit, so my apology if I am mistaken, but surely, there is no other value that can satisfy x except 5?
Couldn't you also by inspection say that if x!=1! that x is either 1 or 0?
dav2008: yes, i could, which means the factorial function is also not injective. But how could a function be injective (assuming my argument is true) and not injective at the same time?
Because it happens to work for 5 (and many other numbers :wink:), but not in general, so not always.
Who is saying that it's injective?
It can't, it's either injective or not :confused:
TD: Yes, it doesn't work for 1!, but why? I'm confused :(
What argument? You've not presented an argument. You do not have a valid argument that ! is injective since it is not. What's the problem? I fail to see the point of this discussion at all.
I think I need to clarify. I don't know if it is injective or not, but if it is not injective, and I'm sorry to repeat this, why if 5! = x! then x=5?
While it TD is right in saying that it wouldn't work for some numbers, I still don't get it. Possibly, there is some circular logic in my argument. I'm not sure...
Because for every value of x other than 0 or 1 x! determines x. So what's the issue?
Why should it work? It simply doesn't because it doesn't follow from the definition of the factorial.
As Matt showed, why should sin(x) = sin(y) imply x = y? It just doesn't.
If a function y=f(x) is non-injective that just means that there exists at least one value y for which f(x1)=f(x2)=y (Well I guess I said it backwards but I think it's clearer saying it that way for this purpose)
It doesn't mean that every single value of y has to have at least two corresponding values of x.
See this diagram of a non-injunctive function: http://upload.wikimedia.org/wikipedia/en/d/dd/Non-injective_and_surjective.png
it's clear that ! is not injective since 0!=1! and 0=/=1 which you know, so that makes me think you fail to understand what injective means.
however, if a function fails to be injective it simply means that there are two different inputs mapped to the same output. it doesn't say anything about the behaviour of the function anywhere else. It is perfectly possible that if we exclude the two points we know of that means it fails to be injective then the on the rest of the domain the function might or might not be injective. all things are possible.
again, what argument?
matt grime: No need to be hostile, I am just a high school student looking to understand a concept. Maybe "argument" is not the correct word since it is only my assumption. I understand to prove a statement, I need to prove it for a general case. So in that sense, 5! = x! means x=5 does not constitute as a proof as it only works for this case.
So, can I just say that since it can't be proven that x! is a one-to-one function, the statement x!=y! does not imply that x = y?
Correct.
Not because it can't be proven, it can even be disproven: 0! = 1! but 0 =/= 1.
So indeed, x! = y! doesn't imply x = y.
whoa a lot of replies.. so the n! function is injective for all values of n except 0 and 1, right?
a demonstration of one case does not constitute a proof the general. However, you've not said what it is you're trying to prove.
well, it can be proven (by example) that it is not injective
correct, and you had the evidence of this in your very first post, which is why I don't see why some 20 posts have been spent on this (and that is not hostility).
To prove something 'for all' whatever you cannot just use one example. However to demonstrate that a statement of 'for all' is false it suffices to find a single counter example (like 0!=1! here). You've just learned the first lesson in what it takes to prove or disprove something.
TD: ok I got it :smile: Thank you.
That depends on your definition of n!
If it is the 'classic factorial' (only defined for natural n), then yes.
Yes, thank you matt grime :wink:
TD: Cool, that clears up a lot of issues!
Thank you all for the help, now I am going to write this answer down!
Good luck with that :smile:
  • · Replies 48 ·
  • · Replies 66 ·
  • · Replies 55 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 44 ·
  • · Replies 19 ·
  • · Replies 20 ·
