Explaining the Change in Heat During Gas Expansion: A Thermodynamics Question
  • Thread starter Thread starter dblanche
    Thermodynamics
The discussion revolves around a thermodynamics problem involving the expansion of gas in a cylinder, where the gas does work on a piston and experiences a change in internal energy. Participants are exploring the relationship between work done, internal energy change, and heat transfer during this process.
  • Participants are attempting to apply the first law of thermodynamics to relate the change in internal energy, work done, and heat transfer. Questions about the correct interpretation of the relationships between these variables are raised.
Some participants have provided guidance on using the first law of thermodynamics, suggesting a formulation that clarifies the definitions of work and heat in relation to the gas. Multiple interpretations of the relationships are being explored, but no consensus has been reached.
Participants are working with specific values for internal energy and work done, but there may be uncertainties regarding the assumptions made about heat transfer and the definitions of the variables involved.
dblanche
Can someone give us a hand in explaining a little about this question??
Gas in a cylinder expands and does 150 joulesof work moving a piston. The Internal energy of the gas changes from 310J to 100J during the expansion.
During this process the change in heat is best described as:
(a): 60J of heat is released by the gas
(b): 360J of heat is released by the gas
(c): 60J of heat is added to the gas
(d): 210J of heat is released by the gas
(e): 210J of heat is added to the gas
Any hints would be much appreciated
Do you have any work or thoughts on the problem? Do you know of any relationships that can relate the heat input to the work done and the change in internal energy?
Use the 1st law of thermo dynamics:
dU = dQ + dW
You are given the change in internal energy (dU), and the work done (dW)
Personally I think it makes more sense to write it as [tex]\Delta U=Q-W_{by}[/tex] where [tex]\Delta U[/tex] is the change in internal energy of a gas, [tex]Q[/tex] is the heat added to the system, and [tex]W_{by}[/tex] is the work done by the system.
That way you have defined all your variables with respect to the gas. A positive W means the gas is doing work (expanding). A negative W means work is being done on the gas (contracting). A positive Q means heat is being put into the gas; a negative Q means heat is being taken out of the gas. A positive change in U means that the internal energy of the gas is increasing; a negative change means its decreasing.
It's easy to realize what's happening if you look at it as: [tex]Q=\Delta U+W_{by}[/tex]. Any heat added to the gas can either go into changing the internal energy of the gas or towards the gas expanding and thus doing work.
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 60 ·
11K
  • · Replies 67 ·
