Can a Permanent Magnet Affect the Capacitance of a Coil?
The discussion revolves around the interaction between a permanent magnet and the capacitance of a coil, particularly in the context of oscillator circuits. Participants explore the inherent capacitance of inductors, the effects of magnetic fields on inductance and capacitance, and the conditions under which these properties may change.
  • One participant suggests that placing a permanent magnet near a coil may cause it to behave like a capacitor, questioning if this applies to air core coils as well.
  • Another participant states that a coil will behave like a capacitor only above a certain frequency.
  • Some participants explain that all inductors have parasitic parallel capacitance and series resistance, and discuss the potential effects of a magnet on the complex impedance of a ferrous-core inductor.
  • One participant inquires about the effects of a magnet on a coil wound around a non-magnetic core, seeking to understand if a small ceramic magnet can enhance the capacitance properties of the coil.
  • Another participant asserts that a magnet will not affect the properties of a coil without ferrous material, although movement of the magnet can induce a voltage in the coil.
  • One participant references the Medhurst formula for calculating capacitance in a coil and seeks clarification on the value of a constant used in the formula.
  • A later reply discusses using an oscillator and a scope to measure the self-capacitance of the coil through resonance, mentioning the use of a Q meter for this purpose.
Participants express differing views on the influence of a permanent magnet on the capacitance of a coil, with some asserting no effect in the absence of ferrous materials, while others explore the potential for changes under specific conditions. The discussion remains unresolved regarding the impact of a magnet on non-ferrous coils.
Participants reference specific formulas and measurement techniques, but there are limitations in terms of assumptions about the conditions under which the effects are observed, as well as the definitions of terms like "self-capacitance" and "inductance." Some mathematical steps and dependencies on frequency are also not fully resolved.
Jdo300
Hello,
I've learned from my study of oscillator circuits that an inductor has some inherent capacitance in it due to the distance between the individual windings. I've heard somewhere that if you place a permanent magnet close to a coil that it will behave like a capacitor and I was wondering if someone out there could confirm or correct me on that. If this is true, does it also work for air core coils as well?
I've never heard that. The coil will behave like like a capacitor, however, above a certain frequency.
All inductors have parasitic parallel capacitance, and series resistance. I don't quite understand your magnet question, but I suppose maybe you're asking about the change in complex impedance of a ferrous-core inductor when it is artificially saturated by an external magnet. If so, then yes, the magnetizing inductance will drop, but the parasitic capacitance will stay the same. You can do the complex math to see what that does to the impedance phasor.
Thanks for the insight. Would you happen to know how the coil might be affected if it is wound around a non-magnetic core? To better explain my setup, I basically want to wind a coil around something like a dowel rod or anything non-magnetic. Then place a small ceramic magnet on the end of the coil to see how it effects the coil if I were to run an AC or DC signal through it, or pulse it. I'm essentually trying to see if the magnet can enhance the capacitence properties of the coil (without it being wrapped around a ferrous core).
No, a magnet will not affect the properties of a coil if there is no ferrous material in the coil construction. Well, if you move the magnet, that will induce a pickup voltage in the coil of course, and if you hold the magnet close to the coil, the ferrous material of the magnet will slightly increase the inductance of the coil. But there will be no effect on the inductance or capacitance of the coil from the presence or absence of the external DC magnetic field.
Okay, thanks for clearing that up for me :-).
ya there is capacitance in a coil, given by C(pF) = K*diameter(cm) as given by Medhurst formula.
but I was unable to know, how to calculate the value of K. can anyone will give me information about "K".
If you have an oscillator and a scope, you can drive the coil via a high resistance and, when the L and self-C resonate (parallel), you will get a voltage peak (when Xc and Xl are equal and opposite). That will tell you the self capacitance of the coil if you already know the inductance at low frequency.
That's the basis of a Q meter, which used to be a good cheap and cheerful way of measuring component values. Your oscillator needs to provide a high enough output frequency to achieve resonance. If it doesn't, you can get smart and introduce a known value of capacitor and infer the self capacitance by the difference between measured and calculated resonance frequencies.
But if your coil is for audio frequency operation, it will probably have a self resonance in the order of tens of MHz, max -easy to achieve. Look up "Q meter" on the web and you'll find something to suit you. i.e. whatever your level of understanding of the topic, high or low.
  • · Replies 35 ·
20K
