Set of stationary points comparation
  • Context: Graduate
  • Thread starter Thread starter tehno
    Points Set
The discussion revolves around the comparison of the total number of stationary points of two functions, A(x) and B(x), defined in terms of nonnegative real functions f(x), g(x), and h(x). The participants explore the implications of the properties of these functions, particularly when they are polynomials, and whether the number of stationary points of A(x) can exceed that of B(x).
  • Some participants argue that little can be definitively said about the relationship between the stationary points of A(x) and B(x), noting that A(x) can have infinitely many stationary points while B(x) has a finite number.
  • One participant provides a counterexample where A(x) has more stationary points than B(x), demonstrating that the relationship is not straightforward.
  • Another participant expresses interest in the case where f(x), g(x), and h(x) are polynomials and seeks a proof for the general case regarding stationary points.
  • There is a discussion about the definitions of stationary points, with some participants clarifying their understanding and the conditions under which they are considering the functions.
  • Some participants propose that under certain restrictions (e.g., nonnegative x and nonzero sums of coefficients), the number of stationary points of A(x) cannot exceed that of B(x), but this remains contested.
  • One participant questions the clarity of another's statements regarding restrictions on polynomial functions and their implications for stationary points.
  • There is a request for proof regarding the conditions under which A(x) may have more stationary points than B(x), indicating ongoing uncertainty and exploration of the topic.
Participants do not reach a consensus on the relationship between the stationary points of A(x) and B(x). Multiple competing views and uncertainties remain regarding the implications of the functions being polynomials and the specific conditions applied.
Participants note limitations in their discussions, including the need for clarity in definitions and the specific conditions under which they are analyzing the functions. There are unresolved mathematical steps and assumptions that affect the conclusions drawn.
This discussion may be of interest to those studying mathematical analysis, particularly in the context of stationary points of functions, polynomial behavior, and the implications of function properties in mathematical reasoning.
tehno
If f(x),g(x),h(x) are nonegative real functions[§] consider functions:
[tex]A(x)=\sqrt{f(x)} + \sqrt{g(x)} + \sqrt{h(x)}[/tex]
[tex]B(x)=f(x)+g(x)+h(x)[/tex]
What can be said concerning the comparation of total number of stationary points of A(x) and B(x)?
If B(x) has ,let say,3 stationary points (and extremes),does that means that A(x) has AT MOST 3 stationary points as well?
[§]=example for functions f(x),g(x),h(x):
[tex]f(x)=|x^3 - 5x^2 + 3x - 9|[/tex]
[tex]g(x)=(sinx)^2[/tex]
[tex]h(x)=x^2 + 1[/tex]
I think very little can be said. Certainly, it's not true that if B has 3 stationary points, then A has at most 3, nor is anything analogous true. Consider f(x) = g(x) = h(x) = x2/9. Then A(x) = |x|, but B(x) = x2/3. B has only one stationary point, 3, but A has infinitely many stationary points - every nonnegative real is a stationary point of A.
What do YOU mean by "stationary point". I would mean a point at which the derivative is 0 but |x| never has derivative 0.
Sorry, I guess I was thinking about "fixed point". My bad.
Yes,exactly that was meant in my post.
The stationary points are defined as solutions of the equations :
[tex]A'(x)=0[/tex],
[tex]B'(x)=0[/tex]
I'm particulary interested in the case when [tex]f(x),g(x),h(x)[/tex] are three polynomials.
HallsofIvy,what can be said then?
Well then?_ ^^_
I prooved the claim if [tex]f(x),g(x),h(x)[/tex] are all three polynomials of the second order (ie. quadratics),and if A(x) , B(x) are restricted to the first Cartesian quadrant.
Can someone give proof ( also for the first quadrant restriction) in general case (when f(x),g(x),h(x) are polynomials of arbitrary order)?
What you're trying to prove is false in general. Note that a polynomial like xd has normally only one stationary point. But there are infinitely many ways to express this as a sum of three polynomials f, g, and h such that the sum of the square roots of f, g, and h has some stationary points. Think about the "other way", i.e. Let A = |p| + |q| + |r|, and say B = p2 + q2 + r2. Then the requirement that f, g, and h be non-negative polynomials becomes the requirement that p2, q2, and r2 be non-negative polynomials. To meet this condition, it suffices to find p, q, and r polynomials. Aside from the strangeness you might get because of the absolute value signs, A is basically just like a polynomial. Suppose it is like a degree d polynomial. Then B will be a degree 2d polynomial. Now since A is like a degree d polynomial, it can have d-1 stationary points. However, if you find a clever way of breaking A up into parts |p|, |q| and |r|, then B will not just be any old polynomial of degree 2d, but it will be something like x2d, which despite its degree of 2d, has only 1 stationary point.
Hi AKG,
Not "in general".
I agree with your point,but rereading my post I think I wasn't clear about
positive restrictions.
Consider:
[tex]A(x)=|\sqrt{|a_{m}x^m+a_{m-1}x^{m-1}+...+a_{0}|}|+|\sqrt{|b_{n}x^n +b_{n-1}x^{n-1}+...+b_{0}|}|+|\sqrt{|c_{p}x^p+c_{p-1}x^{p-1}+...+c_{0}|}|[/tex]
and
[tex]B(x)=|a_{m}x^m+a_{m-1}x^{m-1}+..+a_{0}|+|b_{n}x^n+b_{n-1}x^{n-1}+..+b_{0}|+|c_{p}x^p+c_{p-1}x^{p-1}+..+c_{0}|[/tex]
Consideration to be taken only with nonegative x and if sums of coefficients that belong to terms associating same powers aren't zero.
In that case I think there's no way that number of stationary points of
A(x) can surpass that of B(x).
Do you agree?
This sentence makes no sense. I can't make sense of what you wrote, but I'll tell you what I know:
There exist polynomials f, g, and h defined from the non-negative reals to the non-negative reals such that B = f + g + h has fewer fixed points than A = f1/2 + g1/2 + h1/2. Example:
let d be any odd number greater than 2
let f(x) = ((x-1)2d - 0.5)2
let g(x) = (x-1)2d
let h(x) = 0
Then B(x) = (x-1)4d + 1/4, and has only one stationary point at x = 1. A(x) = |(x-1)2d - 0.5| + |x-1|d which has stationary points at x = 1 and at x = 1 - (1/2)1/d. EDIT: looking at the graph of A(x) for d = 3, I see that it also has another stationary point at 1 + (1/2)1/d, and perhaps this holds for any odd d. Whether it does or not, we know for sure that A has at least the two stationary points I mentioned before the edit, and that is still one more than B has.
AKG said:
This sentence makes no sense. I can't make sense of what you wrote.
Why not?
Restriction means that I consider polynomial functions only
with x>0 and cases where sum of corresponding coefficients of f(x) ,g(x),h(x) is nonzero.
For example :
Let m=n=p=2.
Then
[tex]f(x)=a_{2}x^2+a_{1}x + a_{0};g(x)=b_{2}x^2+b_{1}x+b_{0};h(x)=c_{2}x^2+c_{1}x+c_{0}[/tex]
Assume :
[tex]a_{2}+b_{2}+ c_{2}<>0;a_{1}+b_{1}+c_{1}<>0;a_{0}+b_{0}+c_{0}<>0[/tex]
Okay, so your question can be reasked: Does there exist a natural d, and a polynomial B(x) = adxd + ... + a0 defined on the non-negative reals such that none of the ai are zero, and such that there exist three non-negative polynomials f(x), g(x), and h(x) defined on the non-negative reals such that f(x) + g(x) + h(x) = B(x), and such that the function A(x) = f(x)1/2 + g(x)1/2 + h(x)1/2 has more stationary points than B(x)? You think the answer is "No." Do you have a proof?
Finally,we understand each other!:smile:
No,I don't have proof .I asked for it and would like to see what PFs experts can say about it!
BTW,note that every elementar function in the analysis can be described by serie (ie. in the form of Taylor infinite polynomial).That's reason I'm interested in the proof for the polynomials,under the terms of restriction given above.
With so many conditions, it seems hard to decide on a fruitful way to start. I would recommend expressing the functions f(x)1/2 as power series using Newton's generalized binomial theorem. See if that gets you anywhere.
Not so many conditions.
Simply put :whole thing is considered only in first Cartesian quadrant,with general requirement of the nonzero coefficient sums.
:smile:
To me, the nonzero coefficient sums is quite an unwieldy restriction. Anyways, did the binomial theorem get you anywhere?
Binominal theorem didn't but I solved (prooved) it using
another methods.
Anyway,thank you for the suggestion and correspondence and about all
AKG.
cheers
  • · Replies 20 ·
  • · Replies 53 ·
