Kinetic explanation of evaporation of boiling/Melting.
The discussion focuses on the kinetic explanation of evaporation and melting, specifically addressing the role of latent heat in these processes. It clarifies that the latent heat supplied during evaporation contributes to the potential energy (PE) of escaping molecules, as well as the work needed to expand against atmospheric pressure. Additionally, it emphasizes that while kinetic energy (KE) is relevant at the molecular level, the macroscopic interpretation involves understanding how pressure-volume (PV) work relates to stored energy. The conversation also highlights the distinction between molecular vibrations and the ability to perform work in the context of melting.
  • Understanding of latent heat in phase transitions
  • Familiarity with kinetic and potential energy concepts
  • Knowledge of pressure-volume work in thermodynamics
  • Basic principles of molecular behavior in gases and liquids
  • Research the thermodynamic principles of latent heat and phase changes
  • Explore the relationship between kinetic energy and macroscopic work in thermodynamics
  • Study the concept of pressure-volume work in steam engines and other applications
  • Investigate the molecular dynamics of phase transitions, focusing on energy transformations
Students and professionals in physics, chemistry, and engineering, particularly those interested in thermodynamics and phase transition phenomena.
al_201314
Hi guys
I am slightly confuse about a statement in the kinetic explanation for evaporation as well as melting.
Firstly for the evaporation: "Thus the latent heat supplied in causing evaporation represents the potential energy gain of the escaping molecules plus the work needed to expand against the atmosphere"
I understand that the mean KE drops after some of the molecules go into the air and latent heat is supplied to maintain the mean KE. But how does this extra heat represent the gain in PE of the escaping molecules? My thought is that since the molecules have escaped, how does it gain PE?
Similary, how does the latent heat for melting being regarded as increasing the PE of component of the molecular internal energy? I would have thought that the extra heat would continue to raise the KE to increase the molecules' vibrations for melting.
Thanks for any explanation.
al_201314 said:
Hi guys
Pressure x volume = (Force / Area) Volume = Force x distance = energy
It is a matter of semantics whether one refers to this energy as Potential Energy or Kinetic Energy. It is kinetic energy at the molecular level. But at the macroscopic level, PV represents stored energy that can be used (not completely) to do work (eg steam engine).
You are right if you are looking only at the molecular level. A moving molecule has only kinetic energy.
But at the macroscopic level, the translational Kinetic energy of the gas molecules give them an ability to perform work at the macroscopic level. If the molecules are stuck to each other and are merely vibrating, they do not have (much) ability to do PdV work.
AM
Thanks for the help!
  • · Replies 19 ·
  • · Replies 32 ·
