How Many Beats Are Heard When Three Tuning Forks Are Sounded Together?
The discussion revolves around the phenomenon of beats produced by three tuning forks with frequencies of 100Hz, 101Hz, and 102Hz when sounded together. Participants are exploring how to calculate the total beat frequency resulting from the combination of these three frequencies.
  • Participants discuss the concept of beat frequency when two tuning forks are sounded together and question how this extends to three forks. Some suggest calculating beat frequencies for different pairs of forks and combining results, while others analyze the timing of intensity maxima and minima.
There are multiple interpretations of how to approach the calculation of beat frequency with three tuning forks. Some participants provide reasoning based on combinations of pairs, while others seek clarification on the synchronization of beats from different pairs. The discussion is ongoing, with no explicit consensus reached.
Participants are working under the constraints of understanding beat frequencies without complete solutions. There is a mention of drawing time intensity graphs to clarify the concepts discussed, indicating a need for visual representation to aid understanding.
Amith2006
Sir,
Three tuning forks of frequencies 100Hz,101Hz and 102Hz are sounded together. How many beats will be heard in one second?
If 2 forks are sounded together then the number of beats heard will be equal to the difference of their frequencies. But I don't know how to calculate the beat frequency if 3 forks are sounded together.
Amith2006 said:
Sir,
If you sound the 100 together with the 102, you will get a beat frequency of 2 beats/sec on a frequency of 101 Hz. When the 101 Hz is sounded there are no further beats added. So I would say, 2 beats.
It is a little more complicated to analyse it by sounding the 100 and 101 first and then adding the 102. But if you pair 100 and 101, you get a 100.5 frequency and with 101 and 102 you get 101.5, each with one beat/sec. These two then beat down to 101 with another beat/sec. The beat frequency ends up 2/sec.
AM
One beat period is the interval from minimum to minimum (or maximum to maximum) intensity.
For superposition of waves of frequencies 100 Hz and 101 Hz it is 1 s.
For superposition of waves of frequencies 101 Hz and 102 Hz it is 1 s, and
For superposition of waves of frequencies 100 Hz and 102 Hz it is 0.5 s.
0.5 s after a minimum due to all three, first two combinations gives maximum intensity and hence the next minimum intensity will occur only after 1 s and hence the beat period is 1s and beat frequency will be 1 Hz.
(Draw the time intensity graph for all three combinations separately that will make the things clear)
Please explain. Are you saying that beats from 100 + 101 will be synchronous with the beats from 101 and 102? Why?
AM
  • · Replies 43 ·
