Can the momentum of the sun be affected by the energy it produces?
  • Context: Graduate
  • Thread starter Thread starter Erizo
    Energy Momentum
The discussion revolves around the concept of momentum in relation to the sun, particularly focusing on whether the energy produced by the sun through nuclear reactions affects its momentum. Participants explore the implications of mass-energy conversion, conservation of momentum, and the effects of external gravitational forces on the sun's motion.
  • One participant questions how the sun's momentum could decrease if it is constantly converting mass into energy, suggesting this might violate conservation of momentum.
  • Another participant asserts that light possesses momentum, referencing the momentum of photons as a counterpoint to the initial concern.
  • A different participant challenges the idea that the sun's momentum is decreasing, arguing that the mass lost as radiant energy and solar wind must be accounted for in the conservation of momentum.
  • This participant further explains that the sun's movement is influenced by gravitational interactions with other celestial bodies, indicating that momentum is not the sole factor in its trajectory.
  • They also provide an analogy comparing the sun's mass loss to a bowling ball losing tiny pieces, emphasizing that while the sun's mass and momentum are changing, the changes are negligible compared to its total mass.
Participants express differing views on the implications of mass loss on the sun's momentum and whether this constitutes a violation of conservation laws. There is no consensus on the resolution of these points, and the discussion remains unresolved.
Participants reference concepts such as the momentum of light and gravitational influences, but the discussion does not resolve the assumptions regarding the scale of mass loss or its effects on momentum.
Erizo
I was wondering: From the point of view of an observer who is in motion relative to the sun, the sun has a certain measurable amount of momentum. However, since the sun is constantly turning mass into energy via a nuclear reaction, yet its velocity remains more or less stable, that momentum should be very slowly decreasing. That would violate conservation of momentum.
The only way I can see around this is if the energy being produced has momentum of its own. So can energy have momentum? Does anyone know if it's possible to measure the momentum of, say, a beam of light?
Light has momentum, definitely.
[tex]p_{photon} = \frac{h}{\lambda }[/tex]
Why would that violate conservation of momentum? If the mass is changing, the momentum must also.
Erizo;
First off momentum IS conserved. Keep in mind that all the mass thrown off as radiant energy and solar wind is going someplace. It didn't just disappear. And from a conservation of momentum point of view you have to count that. When you do you'll see that momentum is in fact conserved.
Secondly the Sun's movement through the cosmos isn't determined ONLY by its momentum. It's not an isolated system. It's being pulled on by everything else in the universe. The more massive and closer things are the more effect they have, but even the tiniest sub-atomic particle on literally the other side of the universe has at least some effect on the Sun's movements, its "speed".
Just for example, consider this - if momentum was the only force acting on the Sun then it'd be traveling in a nice straight line instead of orbiting the center of mass of our Galaxy. That right there should tell you that gravitation pull from other objects in the universe have more effect on the Sun's path then its momentum.
Lastly, from a simple accounting viewpoint, if you don't want to count the mass of the Sun lost to radiant energy and the solar wind as being part of "The Sun" proper, the star being observed, then yeah, the momentum of what you're calling "The Sun" IS dropping exactly in line with the amount of mass it's loosing.
Thing is though, that loss of mass is nearly infinitesimally small in comparison to the Sun's overall mass (consider, it's been losing mass like that for billions of years, and billions of years from now it's STILL going to be losing mass). We're talking about a water balloon here with one incredibly small leak in comparison to its size. And, just as the math'll tell ya, the Sun's change in speed due to that fact is going to be equally tiny, all but unnoticeable.
So yeah, the Sun's speed, and mass, and momentum, ARE changing. But it's no more noticeable than the Sun's *drop* in mass compared to it's enormous *overall* mass.
Picture a lead bowling ball rolling down an ally. Every ten feet a piece of the bowling ball the size of a half a grain of sand flies off it. You know, and I know, that under those conditions the mass and therefore the momentum of the lead bowling ball is changing. But how noticable is that change? Not very. What's being lost is too small in comparison to the total mass of the bowling ball, so you see very little change in the bowling ball's mass and momentum. The change IS there, it's just a very tiny change.
That make more sense?
  • · Replies 21 ·
  • · Replies 60 ·
  • · Replies 53 ·
  • · Replies 34 ·
