| Thread Closed |
Electric work and potential difference |
Share Thread | Thread Tools |
| May29-06, 07:44 PM | #1 |
I need a little help with this question:
Calculate the work needed to move a 1.5uC test charge from point B to point D. (I have attached the diagram) The first part of the question required me to find the electric field at the points A, B, C and D. Which I think I figured out ok. I found Eb = 7.66 x 10^6 and Ed = 0 N/C So I think the equation that I need to use is: W = Fd W = qE(dx) whereq = 1.5 x 10^-6C and dx = 0.25m I'm not sure how to figure out E in this case? |
| May29-06, 08:29 PM | #2 |
Mentor
You could certainly use that approach (calculating the work directly), but since the field is not constant you would have to use calculus to integrate E(dx) over the displacement.
Much easier is to consider the change in electric potential energy as the charge is moved. |
| May29-06, 08:51 PM | #3 |
If I were to use the change in electric potential energy I would use:
change in PE = q x dV so PE = q(Vb-Vd) ? |
| May30-06, 01:59 AM | #4 |
| May30-06, 01:05 PM | #5 |
Just one more thing, my answer seems a little large.
To calculate Vd I add Vd1 + Vd2, and the same for Vb which works out to be 2kQ/r where Q is the charges on either side? and r is the distance from each charge to point D? |
| May30-06, 01:18 PM | #6 |
Mentor
Yes, the general form of the potential at D or B will be V = 2kQ/r, where r is the distance from D or B to one of the charges.
| May30-06, 05:51 PM | #7 |
When I was putting all the numbers in I realized that there is no consideration for the distance between point B and D. Is the work needed to move the charge independent of the distance moved?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Electric work and potential difference
| Electric Potential Energy and Electric Potential Difference | Introductory Physics Homework | 2 | ||
| Electric Potential Difference...Please HELP!!! | Introductory Physics Homework | 10 | ||
| Electric potential, potential difference, and potential energy | Introductory Physics Homework | 2 | ||
| Electric Potential Difference | Introductory Physics Homework | 0 | ||
| Electric Potential Difference | Introductory Physics Homework | 3 | ||
