Definition of Static electricity
The discussion revolves around the definition of static electricity, exploring various interpretations and the conditions under which it can be understood. Participants engage in a conceptual examination of static electricity, its relationship to conductors, dielectrics, and the movement of charges.
  • One participant proposes a definition of static electricity as the forces of attraction or repulsion between imbalanced charges on isolated conductors separated by a dielectric.
  • Another participant argues that static electricity can be defined simply as charges that are not moving, emphasizing that it does not require conductors or dielectrics.
  • A third participant agrees with the notion that static electricity relates to the concept of being "not moving," but adds that the process of accumulating charge involves movement, complicating the definition.
  • One participant suggests that electric current should be defined as electrons in motion rather than charges in motion, noting that solutions can also carry current through ions.
  • Another participant emphasizes that a definition of static electricity should not involve conductors, citing examples of charge accumulation on non-conducting surfaces.
  • There is a correction regarding the terminology used, with one participant acknowledging a mistake in referring to charges instead of electrons.
  • One participant challenges another's definition of a conductor, asserting that it is incorrect.
Participants express differing views on the definition of static electricity, with no consensus reached. Some argue for definitions that include conductors, while others reject this notion, leading to an ongoing debate.
Participants highlight the complexity of defining static electricity, noting the implications of charge movement and the role of different materials in charge accumulation. There are unresolved aspects regarding the definitions and the conditions under which static electricity can be understood.
McQueen
I have come up with the following definition of static electricity , which I hope is acceptable to all , if not I would be only too glad to hear any opinions. “Static electricity may be defined as the forces of attraction or repulsion felt between an imbalance of charges on isolated conductors separated by a di-electric. “ Note that the operative word here is isolated.
But static electricity does not require any conductors or dielectric.
"Static electricity" can really only be defined one way: "charges that are not moving."
- Warren
I would agree with Warren.
The term "static electricity" can be defined through the use of the first word, static, which means "not moving", as Warren simply put.
As a side note, remember how one can shuffle themselves over carpet and "shock" someone else? This is static electricity, but not entirely.
The building up of excess charge within the body involves charge movement, so that stage is by no means static. When the "spark" or "shock" occurs, the charges are obviously moving, so, that is not static electricity either. In this scenario, the only true "static electricity" is involved with the interval between being charged and releasing that charge.
- Warren
So electric current is charge in motion right?
Originally posted by mighty2000
Electric current begins when electrons begin randomly bouncing off of the ion lattice within a conductor. A charge is required to start the current in a direction whether induced or not. Therefore, I would define it more as electrons in motion rather than charges in motion, even though electrons carry a charge of 1.60x10^-19 Coulombs.
M2k
A more general definition of current is charges in motion. What you say is correct for metallic conductors. Solutions can also carry current in which case the current carriers are ions.
A definition of static electricity should not involve the term "conductor" since it is very common for a charge to accumulate on non conducting surfaces. Consider on of the original methods of generating a charge. Rubbing cat fur on amber, both of these materials are non conductors.
M2k
Of course. I meant electrons, not charge. Silly me..
You were better off with charge. See Integral's example of ions in a solution.
If you notice in my post I took care not to mention the term electrical conductors but had merely used the term “conductor” which in view of the fact that static charges do tend to accumulate on them seems to be acceptable . Secondly the term “isolated” has been used to indicate that an isolated conductor gains a very high voltage potential. If this were applied to electrical conductors it would be totally unacceptable , for instance the Coulomb repulsion between two 120 watt electric bulbs turned on for a second and separated by 1 metre would be in excess of I million tons of force !
I'm sorry McQueen, it won't help you to try redefining the term 'conductor.' Your definition is simply not correct.
- Warren
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 22 ·
