| Thread Closed |
Separation of Isotopes by Laser Excitation |
Share Thread | Thread Tools |
| May31-06, 10:31 AM | #1 |
| May31-06, 07:12 PM | #2 |
Seems like it. Look here: http://www.silex.com.au/
| Jun1-06, 08:33 AM | #3 |
Recognitions:
Actually this technology was developed in the early '70s at Lawrence Livermore National Laboratory: http://www.llnl.gov/50th_anniv/decades/1970s.htm [Scroll down to the entry for the year 1973 ] The process is called AVLIS - Atomic Vapor Laser Isotope Separation. Here's how it works. The equations of Quantum Mechanics that describe how electrons "orbit" atoms contains in one of its terms the mass of the electron. However, since the electron orbits a nucleus of finite mass; this is a "two-body" problem - and one has to use the so-called "reduced mass" of the electron - m = m*M / (m + M) where "m" is the electron mass, and "M" is the mass of the nucleus. Therefore, the mass of the nucleus "M" enters into the equations that define the orbits of the electrons. When you do the calculations, you will find that the "ionization potential" - that is the amount of energy you have to add to the outermost electron to kick it free and form a charged ion - is very slightly less for U-235 than it is for U-238. You then need a VERY precise tunable laser. LLNL developed a tunable dye laser pumped by copper vapor lasers. You tune the laser to a frequency so that the laser photons have enough energy to ionize U-235; but not enough energy to ionize U-238. You send this laser zig-zagging through a chamber of UF6 gas or vaporized U and the laser will ionize the U-235, but not the U-238. The U-235 can then be deflected electrostatically by a charged plate into a separate stream from the U-238. To learn more about AVLIS, tunable laser applications, and a spin-off from this work called the "laser guide star" - a powerful new tool for astronomers first deployed on the 3m Shane telescope at Lick Observatory - but now in use at largest telescopes in the world - the Keck telescopes on Mauna Kea in Hawaii; see: www.llnl.gov/str/pdfs/05_00.2.pdf Dr. Gregory Greenman Physicist |
| Jun1-06, 10:06 AM | #4 |
| Jun1-06, 10:52 AM | #5 |
Recognitions:
You may be correct. I forget whether U-235 absorbs at a lower frequency - in which case it has a lower ionization potential; or at a lower wavelength [ higher frequency ], in which case it has a higher ionization potential. Dr. Gregory Greenman Physicist |
| Jun1-06, 11:08 AM | #6 |
Admin
According to Wikipedia - The absorption lines of 235U and 238U differ slightly; for example, the 238[/sup]U absorption peak shifts from 5027.4 Angstroms to 5027.3 Angstroms in 235U. According to the UWisc NE notes, the wavelength used to ionized U-235 is 5915 Å, so I'll have to find other references to clarify. Some discussion here - http://fti.neep.wisc.edu/neep423/FALL99/lecture8.pdf Contrary to what other sources say, USEC took over ALVIS from LLNL then abandoned it. Just the Facts: The USEC Business Other interesting data - Table of Ionization Energies (eV) of Atoms and Ions - http://www.astro.lsa.umich.edu/~cowley/ionen.htm |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Separation of Isotopes by Laser Excitation
| intensity of red laser vs blue laser | Advanced Physics Homework | 4 | ||
| Separation of variables and the separation constant | Calculus & Beyond Homework | 4 | ||
| Double slit problem, finding λ of second laser given data about first laser... | Introductory Physics Homework | 2 | ||
| Are there fissionable isotopes of any element with short-lived radioactive isotopes? | Nuclear Engineering | 48 | ||
| Isotopes | Biology, Chemistry & Other Homework | 3 | ||
