Carnot Cycle and Line Integrals
The discussion focuses on correlating the Carnot cycle with line integrals, emphasizing that line integrals can calculate work done by a vector field along a path. The Carnot cycle establishes a theoretical limit on engine efficiency, relevant to thermodynamics. Participants suggest using Green's theorem to relate line integrals to the area within the cycle, while also clarifying that real engines operate on different cycles, such as the Otto and Diesel cycles, rather than the Carnot cycle. The ideal nature of the Carnot cycle is highlighted, particularly its applicability to quasi-static transformations and its connection to the Clausius theorem.
  • Carnot cycle principles
  • Line integrals in vector calculus
  • Green's theorem in mathematics
  • Basic thermodynamics concepts
  • Study the application of Green's theorem in thermodynamics
  • Explore the Clausius theorem and its implications for real-world engines
  • Research the differences between the Carnot, Otto, and Diesel cycles
  • Examine the role of quasi-static processes in thermodynamic cycles
Students and professionals in physics and engineering, particularly those interested in thermodynamics, vector calculus, and the efficiency of heat engines.
longbusy
I have to corellate the Carnot cycle with line integrals. This makes sense to me as line integrals can be used to find the work done by a vector field on an object traveling along a certain path. The Carnot cycle places a limit on the efficiency of an engine cycle.
My question, how could I specifically compare line integrals to the Carnot cycle. Maybe the effect that heat has on the system? I'll attach what I have written so far. Thanks!
(Edit: I attached the .doc file but I do not see it on my post.)
You could try using Green's theorem to relate the Line Integrals around the cycle to the area inside the region, however since when using Green's theorem you usually go around the region counterclockwise it would be in the wrong direction of your cylce.
You might want to start having a look at http://scienceworld.wolfram.com/physics/topics/ThermodynamicCycles.html.
The first remark on your doc is that you are assuming car engines run on a Carnot Cycle which is not true since gasoline cars use Otto cycle and diesel cars use Diesel cycle.
Besides that you have to consider that Carnot Cycle is an ideal representation valid for quasi-static (reversible) transformations. This ideal representation set a limit to real world engines through the so called Clausius Theorem that is based on line integrals.
I will write you more tomorrow... search the internet for a decent thermodynamic textbook.
DArio
15K
