Calculating Temperature Change for Steel Rod Stretching
The discussion focuses on calculating the temperature change required to elongate a steel rod under a stretching force of 500 N with a cross-sectional area of 2 cm². The participant employs Young's modulus, specifically using a value of 20 x 10¹⁰ Pa for steel, to determine the change in length (ΔX). The challenge arises in calculating the initial length (L_initial) needed for the linear expansion formula, which incorporates the average coefficient of linear expansion for steel, 11 x 10⁻⁶. The participant seeks clarification on how to derive or substitute the initial length in the calculations.
  • Understanding of Young's modulus and its application in material science
  • Knowledge of linear thermal expansion principles
  • Familiarity with basic physics concepts such as force, area, and stress
  • Ability to manipulate equations involving thermal expansion and material properties
  • Research the derivation and application of Young's modulus in different materials
  • Learn about the calculation of thermal expansion in solids, specifically for metals
  • Explore methods to determine initial lengths in material deformation problems
  • Investigate the relationship between stress, strain, and temperature changes in materials
Students and professionals in engineering, physics, and materials science who are involved in the analysis of material properties and thermal effects on structural components.
parttime
a steel rod undergoes a streching force of 500n its crossectional area is 2cm^2 find the temp change that would elongate the rod by same amount
i useyoungs modulus to get change in length so ym= (F/A)/(deltaX/h)
so i solve for r (which is = to h from area of circle) and with a ym for steel of 20*10^10 i get delta X now i plug that into equation for linear
which is deltaX = (average coeffiecent of linear expation for steel) = 11*10^-6 Linitial(which is what is giving me problems) *delta T (temp)
i am not given the initial length how am i supposed to come up with it or substitute it for some other value??
What is r? h should be the length of the rod. When you do the thermal expansion, the length drops out.
AM
  • · Replies 24 ·
