HELP Induced Voltage question
  • Thread starter Thread starter Trista
    Induced Voltage
The discussion centers on calculating the maximum induced voltage in a coil with 10 turns, shaped as an ellipse, rotating at 100 RPM within the Earth's magnetic field of 55 microteslas. The formula used is Emax = NBAω sin(ωt), where the area A is calculated as 1.26 m². The user initially miscalculated the area and later corrected it, concluding that the induced voltage is 18.1 microvolts when the coil is perpendicular to the magnetic field and 0 volts when parallel, as no magnetic field interacts with the coil in that orientation.
  • Understanding of electromagnetic induction principles
  • Familiarity with the formula Emax = NBAω sin(ωt)
  • Knowledge of coil geometry and area calculation for elliptical shapes
  • Basic understanding of angular velocity and its conversion from RPM to rad/s
  • Study the effects of coil orientation on induced voltage in electromagnetic systems
  • Learn about the calculation of induced voltage in different magnetic field configurations
  • Explore advanced concepts in electromagnetic induction, such as Faraday's Law
  • Investigate the practical applications of induced voltage in electrical engineering
Students and professionals in electrical engineering, physics enthusiasts, and anyone interested in the principles of electromagnetic induction and coil design.
Trista
HELP! Induced Voltage question
Here it is: Coil has 10 turns and shaped in an elipse (A = pie ab), having a major axis of 10 cm (10 X 10^-2 m) and minor axis 4 cm (4 X 10^-2m). Coil rotates 100 rpm in a region in which the magnitude of the Earth's magnetic field is 55 microT. What is max voltage induced in the coil if the axis of rotation of the coil is along its major axis and aligned
a) Perpendicular to Earth's magnetic field or
b) parallel
So, I figure my equation should be Emax = NBA omega sin omega t
Then, I figure my area to be: A = pi ((10 X 4)x10^-2 m^2)) = 1.26 m^2
and Omega = 2 pi(rpm / 60) -> 2 pi (100 / 60) = 10.47 rad/s
My equation then looks like this:
10(55X10^-6 T)(1.26 m^2)10.47 rad/s sin 10.47 rad/s t
But it doesn't come out right AND I don't know what t would be, as its not mentioned. a) is supposed to be 18.1 micro V and b) is 0, I suppose because it is parallel, no magnetic field is hitting it when parallel, right?
hahhaahaha, I got it... I needed to fix my area. S/B (4 cm / 2)(10 cm / 2) = 10 cm... got my answer, thanks anyway
