Thread Closed
Thermonuclear fusion
Share Thread Thread Tools
Jun10-06, 09:41 AM   #1
I just need a little help in interpreting a question.
Question
Identify the terms in the above two expression and give their physical significance
What do you think they mean by physical significance?
These are the two expressions by the way.
[tex]\epsilon = n_a n_x \frac{< \sigma V >} {\rho}[/tex]
[tex]< \sigma V > =( \frac {8} {m \pi})^{1/2} (kT)^{-3/2} \int_{0}^{100000} S(E) e^{(\frac{-E} {kT} - \frac {b} {E^{1/2}})} dE[/tex]
What I've done is explain all the terms in these expressions
na = number of particles per unit volume of nuclide a
nx = number of particles per unit volume of nuclide x
Q = Energy per reaction
[tex] \rho[/tex] = density
[tex]\epsilon[/tex] = power generated per unit mass
[tex]<\sigma V >[/tex]= the velocity integrated cross-section
m = reduced mass of the target-projectile system.
k = Boltzmann’s constant.
T = temperature of the system
S(E) = cross-section factor
E = Energy
b = this is just a term that simplifies the equation and here all I did was I gave the full expression.
I was thinking that maybe the physical significance would be to say that [tex] e^{\frac {-b} {E^{1/2}} [/tex] is the probability of penetration of the energy barrier and [tex] e^{\frac{-E} {kT}}[/tex] is the maxwellian distribution etc.??
P.S. The integral is meant to be infinity but I didn't know the syntax
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun10-06, 01:48 PM   #2
Admin
[tex]\infty[/tex] "[tag]\infty[/tag]" gives infinity. Check the LaTeX thread.
Typesetting in LaTeX - http://physicsforums.com/showthread.php?t=8997
I believe b is the impact parameter, or is related. The 'b' must have units of [itex]\sqrt{energy}[/itex], so is related to velocity or momentum.
From what text is the second expression for [itex]<\sigma V >[/itex]?
Here is some useful discussion on distributions, particularly Maxwell-Boltzmann. See plate 3.
http://hyperphysics.phy-astr.gsu.edu...um/disfcn.html
http://hyperphysics.phy-astr.gsu.edu...disfcn.html#c1
Jun10-06, 05:53 PM   #3
yes, your physical intuition about the physical significance is correct.
The exp(-E/kT) comes from the Boltzmann distribution, the exp(-b/sqrt(E)) comes from the penetration factor. The first function decreases with energy (there are less fast particles), the second increases (it is easier for fast particles to tunnel through the potential barrier. When you multiply the two functions, you get the Gamow Peak. Check it out in google.
b comes from the tunneling calculation. It is: [latex]b \equiv {\sqrt{2\mu} \pi Z_a Z_b e^2 \over \hbar}[/latex]. The full tunnelling + reaction includes also the nuclear cross section which enters through S(E).
In the sun, the Gamow peak comes out to be at about 5 times kT while other reactions have it much higher (e.g., 20 times kT for typical CNO reactions)
NJS
Jun11-06, 10:31 AM   #4
Thanks a lot for you help guys. That's cleared the question up.
Thread Closed
Thread Tools
Similar Threads for: Thermonuclear fusion
Thread Forum Replies
Hypothetical: Large Thermonuclear Detonation Nuclear Engineering 4
Thermonuclear plasma turbine powerplant? Nuclear Engineering 29
Fusion in sun Cosmology 6
Thermonuclear device to destroy hurricanes Brain Teasers 2
global thermonuclear war Introductory Physics Homework 1
