Calculate pH/pKa: pH 4.0, HA Aqueous Solution
  • Thread starter Thread starter Huskies213
The pH of a 150 mL aqueous solution of 2.13 x 10^-3 M HCl is calculated using the formula pH = -Log(2.13 x 10^-3), resulting in a pH of 2.672. For the second query regarding a 0.1 M aqueous solution of acid HA with a pH of 4.0, the pKa can be determined by rearranging the formula for pH to find Ka, and subsequently calculating pKa. The discussion emphasizes the importance of significant figures in reporting results, suggesting a pKa of approximately 2.67 based on the provided pH.
  • Understanding of pH and pKa concepts
  • Familiarity with logarithmic calculations
  • Knowledge of acid dissociation constants (Ka)
  • Basic chemistry principles related to aqueous solutions
  • Study the relationship between pH, pKa, and Ka in acid-base chemistry
  • Learn how to rearrange the pH formula to solve for pKa
  • Review significant figures in scientific calculations
  • Explore online resources or lectures on pH calculation techniques
Chemistry students, educators, and professionals involved in analytical chemistry or acid-base equilibria who seek to deepen their understanding of pH and pKa calculations.
Huskies213
First is this correct?
The pH of a 150 mL aqueous solution of 2.13 x10^-3 M HCl is
pH = -Log (2.13 x10^-3)
pH = 2.672
and how would you solve this one?
A .1M aqueous solution of an acid HA has a pH of 4.0 what is the pKa of HA?
First is, indeed, correct. :approve:
I cannot help until you express some of your thoughts. Sorry, I must respect the rules. :frown:
Suggestion: What information gives you the question when she says the pH is 4 to help you find Ka and, then, pKa?
Check: http://en.wikipedia.org/wiki/PKa
2.67, as you used more significant digits in your answer than you had in the input data.
As for the second question - what formula do you use for pH calculation? Can it be rearranged/solved for pKa?
Check these pH calculation lectures.
  • · Replies 16 ·
