How do you calculate the work done in an adiabatic process?
The discussion revolves around calculating the work done in an adiabatic process, focusing on the relationship between thermal energy, temperature changes, and volume variations. Participants explore different methods and equations relevant to thermodynamics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using the change in thermal energy and the integral of pressure with respect to volume to find work. Questions arise about determining temperature changes and the implications of the adiabatic condition on calculations.
Several participants have offered different approaches to the problem, including integrating specific equations and applying the adiabatic condition. There is an ongoing exploration of how to relate temperature and volume changes, with no explicit consensus reached yet.
Some participants express uncertainty regarding constants and the application of different pressures and volumes in their calculations, indicating potential gaps in information or understanding of the adiabatic process.
pivoxa15
I know change in thermal energy = work done.
which amounts to (f/2)Nk(change in T). But how do you get change in T?
Or is there another way to compute the work directly. The trouble is both the volume and temperture vary during the process.
(1) [tex]W = \int PdV = nR\int TdV/V[/tex] (substituting P = nRT/V)
But the adiabatic condition [itex]PV^\gamma = nRTV^{\gamma-1} = K[/itex] applies, so (1) becomes:
[tex]W = K\int dV/V^{\gamma}[/tex]
Determine that integral for a particular volume change and that is the work.
AM
But do you think it is easier to find the change in internal energy hence only change in temperture between the two states? This will give the work as Q=0.
You could take that approach. You apply the adiabatic condition in terms of temperature and integrate [itex]\int nC_vdT[/itex] from initial to final temperature. But you have to apply the adiabatic condition to find the initial and final temperatures.
That will give you the change in internal energy. You then equate that to the work done (since, as you point out, Q = 0, [itex]\Delta U = \Delta W[/itex].
But because you have to use the adiabatic condition [itex]T = K/nRV^{\gamma-1}[/itex] it is essentially the same calculation that I have set out above.
The integral:
[tex]K \int_{V_i}^{V_f} V^{-\gamma}dV[/tex]
is not that difficult to work out using antiderivative of [itex]V^{-\gamma}[/itex] = [itex]V^{-\gamma +1}/(-\gamma + 1)[/itex]
[tex]W = K(V_f^{1-\gamma} - V_i^{1-\gamma})/1-\gamma[/tex]
AM
AM
I don't take the integral. I just use the adiabat relation to find the initial and end tempertures in terms of one temperture that I know the value to such as the initial temperture.
The integral evaluates to [tex]nC_v(T_f - T_i)[/tex]. Is that not what you use? How do you find the beginning and end temperatures?
AM
Just to do the math to make my point clearer:
[tex]T= K/nRV^{\gamma-1}[/tex]
So:
(1) [tex]nC_v(T_f - T_i) = nC_v\frac{K}{nR}(V_f^{1-\gamma} - V_i^{1-\gamma})[/tex]
But [tex]C_v = C_p-R = C_v\gamma - R[/tex] so
[tex]C_v = \frac{R}{\gamma-1}[/tex]
Substituting in (1):
[tex]nC_v(T_f - T_i) = \frac{K}{(\gamma-1)}(V_f^{1-\gamma} - V_i^{1-\gamma})[/tex]
Thus:
[tex]\Delta U = -\Delta W[/tex]
AM
I have the same problem but is K a constant?
Oh I wasn't sure! Thanks!
is that little symbol 7/5 for diatomic? and 5/3 for monatomic?
i got a really small number...
whoops. silly me. k is just a constant, from adiabatic condition [itex]pV^\gamma[/itex]=constant
let me try that and see how that works.
hold on i have 2 different pressures and volumes and i have K=pV^alpha...which do i use or what do I do.
there is my problem...
  • · Replies 19 ·
  • · Replies 81 ·
9K
  • · Replies 22 ·
  • · Replies 60 ·
11K
