Optimizing Pool Water pH: Calculating Volume of Acid Needed for Perfect Balance
  • Thread starter Thread starter Taryn
    Acid Volume
The discussion focuses on calculating the volume of hydrochloric acid (HCl) needed to lower the pH of a newly built swimming pool from 7 to 4. The pool dimensions are 7.5m x 5m x 1.5m, resulting in a total volume of 52.5m³ or 52,500 liters. The acid concentration is 33.0g/100ml, which translates to a molarity of approximately 9.052 moles per liter. The final calculation involves using the formula [H3O+] = Vacid(Macid)/(Vi + Vacid) to determine the required volume of acid.
  • Understanding of pH and hydronium ion concentration
  • Basic knowledge of molarity and molar mass calculations
  • Familiarity with algebraic manipulation for solving equations
  • Knowledge of acid-base chemistry, specifically HCl behavior in water
  • Learn about the relationship between pH and hydronium ion concentration
  • Study the concept of molarity and how to calculate it from mass and volume
  • Explore algebraic techniques for manipulating chemical equations
  • Research common methods for adjusting pool water chemistry effectively
Pool owners, chemistry students, and anyone involved in maintaining swimming pool water quality will benefit from this discussion.
Taryn
You have just built a swimming pool that has the dimensions of 7.5m in length and is 5 metres in width.
When filled with water the depth of the pool os exactly 1.5metres.
The lable on the 5 litre pool acid bottle indicates that this has a conc of 33.0g/100ml of HCl. Makin the assumption that the initial volume of pool water had a pH of 7 calculate the volume of pool acid you would need to add to the pool to bring the pH of the pool water to a value of 4.
This is wat I did, noting that I am a shocker at anything to do with pH, which is y I am trying to work out this qu b4 exams on mon!
Volume of the pool=52.5m^3=52500L
I sed that pH=pKa-[H30+]
7= 4-log[H30+]
[H30+]=0.001
then I sed that v=n/c
This is the dodgey thing that I did, I sed that in 1L there was 330g
Then n=330/36.453= 9.052mol
V= 9.052/0.001=9052
Then what? is that right? I feel as though I have done something wrong
If you have any idea of wat to do next or how to help agen I would be much appreciative.
And also just a general way or process of steps to solving pH problems I would also be appreciative
Here's the general outline for solving this problem,
The total volume of the pool as the acid solution is added is Vi+Vacid.
The final desired pH of 4 has an hydronium acid concentration associated with it, use pH=-log[H3O+].
[H3O+]=moles of HCl/(Vi+Vacid), however moles of HCl is Vacid(the molarity of the acid solution)
Thus what you need to solve for finally is
[H3O+]=Vacid(Macid)/(Vi+Vacid), all are constants except Vacid, solve for Vacid through algebraic manipulation. Have fun!
17K
