Counting Marbles in Boxes: Solving Tough Combinatorics Problems
  • Context: Graduate
  • Thread starter Thread starter qbert
    Combinatorics
The discussion focuses on combinatorial mathematics, specifically the problem of distributing M identical marbles into N boxes with a maximum limit of k marbles per box. The solution involves using combinations and factorials to derive the total configurations. For k equal to M, the formula is (M+N-1) choose M, while for k equal to 1, the configurations are represented by N choose M. The general formula for arbitrary k is derived by subtracting invalid arrangements from the total possible arrangements.
  • Understanding of combinatorial mathematics
  • Familiarity with factorial notation and combinations
  • Knowledge of the concept of permutations
  • Basic algebraic manipulation skills
  • Research the concept of generating functions in combinatorics
  • Learn about the stars and bars theorem for distributing indistinguishable objects
  • Explore advanced combinatorial identities and their proofs
  • Study the application of combinatorial methods in algorithm design
Mathematicians, computer scientists, and students studying combinatorics or algorithm design will benefit from this discussion.
qbert
I've just managed to stump myself. Let's say you have
M (identical) marbles and N boxes. How many ways
can you put the marbles in the boxes if each box
can have at most k (k <= M) marbles?
for k=M we can take M .'s to be the marbles
and N-1 |'s to be the boxes so a valid configuration
is a sequence like ..|.|...||.. so we end up with
(M+N-1) choose M.
for k=1, we must have M<N, and
we have N choices for the first marble,
N-1 choices for the second, ...
which is just N choose M possibilities.
is there a formula for arbitrary k?
The trick here is to subtract the invalid orderings.
first, let [tex]t = n+m-1[/tex] to simplify things a bit.
If we can separate the m balls into n boxes without restriction we get n-1 bars and m balls:
[tex]N_{all} = \frac{t!}{m!(n-1)!}[/tex]
If we want to make sure we have at least k+1 balls in a box, we group k+1 balls together and treat them like they're a single weird ball. An example of this is ".|..|{...}.|||", where three of the balls are placed in a set. Then we have n-1 bars, m-(k+1) balls, and 1 weird ball (note that I still divide by m! because you can swap balls within the weird ball with balls outside of it):
[tex]N_{remove} = \frac{((n-1)+(m-(k+1))+(1))!}{m!(n-1)!}[/tex]
[tex]=\frac{(n+m-k-1)!}{m!(n-1)!}[/tex]
[tex]=\frac{(t-k)!}{m!(n-1)!}[/tex]
Now, all the permutations we want to remove just happen to have at least k+1 balls together, so:
[tex]N = N_{all} - N_{remove}[/tex]
[tex]=\frac{t!}{m!(n-1)!} - \frac{(t-k)!}{m!(n-1)!}}[/tex]
[tex]=\frac{t! - (t-k)!}{m!(n-1)!}[/tex]
not counting any stupid errors I made, of course.
EDIT: Fixed a mistake (forgot to include balls within weird ball in the denominator)
so we meet again, subtraction--my arch enemy!
That was exceedingly clever. Thanks for your help.
  • · Replies 29 ·
