Solving Thermodynamics Problems: Compute C_v and Heat Capacity
  • Thread starter Thread starter cukitas2001
    Thermodynamics
This discussion focuses on calculating the specific heat capacity at constant volume (C_v) for nitrogen (N_2) gas and related thermodynamic problems. The specific heat capacity for diatomic gases like N_2 is defined as C_v = 5/2 R, where R is the ideal gas constant. Participants also explore the heat required to raise the temperature of a diatomic ideal gas and the implications of using C_v versus C_p. The conversation highlights the importance of understanding the distinction between specific heat capacities and the conditions under which they apply.
  • Understanding of thermodynamics principles, particularly heat capacity
  • Familiarity with the ideal gas law and its applications
  • Knowledge of diatomic and monatomic gas properties
  • Basic skills in unit conversion for specific heat capacity (J/kg/K)
  • Learn about the ideal gas constant (R) and its applications in thermodynamics
  • Study the differences between C_v and C_p for various gases
  • Explore the calculations for heat transfer in thermodynamic processes
  • Investigate the behavior of gases under varying pressure and volume conditions
Students and professionals in physics and engineering, particularly those focusing on thermodynamics, heat transfer, and gas properties.
cukitas2001
ok these last few problems have been driving me up a wall an of course its got to be something simple I am missing.
1)
A) Compute the specific heat capacity at constant volume of nitrogen ([tex]N_2[/tex]) gas. The molar mass of [tex]N_2[/tex] is 28.0grams/mol.
the heat capacity of a diatomic molecule is:
[tex]C_v =\frac{5}{2} R[/tex] but i don't think this is what I am suppsoed to use? help please
B) You warm 1.10kg of water at a constant volume from 18.0 celsius to 30.5 celsius in a kettle. For the same amount of heat, how many kilograms of 18.0 celsius air would you be able to warm to 30.5 degrees? Make the simplifying assumption that air is 100% [tex]N_2[/tex].
C)What volume would this air occupy at 18.0 celsisu and a pressure of 1.11 atm ?
I'm pretty sure if i figure out B i can solve C
2)
A) How much heat does it take to increase the temperature of n moles of a diatomic ideal gas by an amount [tex]\Delta\,T[/tex]near room temperature if the gas is held at constant volume? Use R for ideal gas constant.
Well [tex]C_v =\frac{5}{2} R[/tex] but this doesn't include any temperature changes so what else is available to use?
B)What is the answer to the question in part (A) if the gas is monatomic rather than diatomic?
Again i think if i can figure out A i can answer B
3) this is posted in another thread so check out my other thread please :redface:
nvm figured these out but still need help on the question in other thread...help pleasse
1a) Why not use it ... isn't N_2 diatomic?
The issue is to get Specific Heat Capacity in familiar units ... [J/kg/K].
1b) The ambiguity here is that Cv (part a) is NOT equal to Cp.
1c) Apparently, this air is in a Pressure container, so it CAN be kept at V.
2) "doesn't include any Temperature change" What do you think Cv IS?
  • · Replies 33 ·
