Torque Req. for Fixed Rot. Acc.
  • Thread starter Thread starter Beyond Aphelion
    Torque
The discussion focuses on calculating the torque required to accelerate a merry-go-round from rest to 18.0 rpm in 10.1 seconds. The merry-go-round is modeled as a disk with a radius of 2.30 meters and a mass of 830 kg, with two children each weighing 25.4 kg sitting on the edge. The initial calculation for angular acceleration was determined to be approximately 0.186629 rad/s². The correct approach involves calculating the total moment of inertia, which includes the contributions from both children and the disk, leading to the correct torque calculation.
  • Understanding of angular kinematics, specifically the equation ωf = ωi + αΔt
  • Knowledge of torque calculation using τ = Iα
  • Familiarity with the moment of inertia for different shapes, particularly I = ½MR² for disks
  • Ability to convert rotational speeds from rpm to rad/s
  • Learn how to calculate the total moment of inertia for composite systems
  • Study the relationship between torque and angular acceleration in rotational dynamics
  • Practice converting rotational speeds from rpm to rad/s for various scenarios
  • Explore the effects of frictional torque on rotational motion
Physics students, mechanical engineers, and anyone interested in understanding torque and rotational dynamics in practical applications.
Beyond Aphelion
I'm having difficulty with this question:
A day-care worker pushes tangentially on a small hand-driven merry-go-round and is able to accelerate it from rest to a spinning rate of 18.0 rpm in 10.1s. Assume the merry-go-round is a disk of radius 2.30m and has a mass of 830kg, and two children (each with a mass of 25.4kg) sit opposite each other on the edge. Calculate the torque required to produce the acceleration, neglecting frictional torque.
Alright, this is my process; although, I know my end result is wrong:
I used the angular kinematic equation to solve for the angular acceleration.
f = ωi + αΔt)
I got α = 0.186629 rad/s² (approx.) after converting from rpm's.
The equation I have for torque is:
τ = mr²α
But, since we're working with a disk, I = ½MR².
Therefore, I solved for torque using the equation:
τ = ½MR²α
I'm moderately confident with myself at this point, although I realize I can be completely off, but I think I'm screwing up what to use for mass.
I plugged in the mass of the merry-go-round plus the mass of the two children.
M = 880.8 kg
Most likely, this is where my reasoning is flawed. I've just recently been introduced to torque, and it is honestly confusing me.
Anyway. The answer I got:
τ = ½MR²α = τ = ½(880.8 kg)(2.3)²(0.186629 rad/s²) =
434.79 N*m
This is the wrong answer, I know. But it is the best I could come up with based on the information my textbook is giving me. Any advice would be helpful.
f = ωi + αΔt)
τ = mr²α
τ = ½MR²α
For a point mass, I is MR^2 (where R is the distance from the point mass to the axis of rotation). For a disk, the moment of inertia is 1/2 MR^2. What you have to do here is to calculate the total moment of inertia, with is [itex]I_{total}=I_{child#1} + I_{child#2} + I_{disk}[/itex]
Use this for the total moment of inertia. barring any algebra mistake, this should work.
Patrick
12K
