Mixture of saturated liquid and saturated vapor
The discussion revolves around the concepts of saturated liquid, saturated vapor, and the mixture of both phases in thermodynamics, particularly in relation to phase diagrams and boiling points. Participants explore the definitions and implications of being in the mixture region versus being a subcooled liquid, along with specific examples involving different substances.
  • Some participants describe the phase diagram showing the saturated liquid and vapor lines, noting that the region between these lines represents a mixture of both phases.
  • There is a claim that a subcooled liquid is defined as being below the boiling temperature, leading to confusion about how a mixture could be considered a pure liquid.
  • One participant suggests that in the saturation region, the mixture consists of both liquid and vapor, and the specific enthalpy determines the proportions of each phase.
  • Another participant raises a specific example involving a liquid at 60°C with a boiling point of 120°C, questioning whether it can be concluded that the liquid is pure and without vapor.
  • Participants reference data from the Perry Chemical Engineers' Handbook regarding the boiling points of H2SO4 and NaOH, questioning the implications of their respective states at a given temperature.
Participants express confusion and uncertainty regarding the definitions and relationships between subcooled liquids, saturated mixtures, and boiling points. There is no consensus on how to interpret these concepts, and multiple viewpoints are presented without resolution.
Participants highlight the need for clarity on the definitions of subcooled liquids and the conditions under which a mixture can be classified as a pure liquid. The discussion indicates a reliance on specific data and diagrams that may not be fully understood by all participants.
pikkie
In the figure that shows saturated vapor and liquid condition under varying temperature and specific volume (constant temperature), there are 2 lines, 1 is saturated liquid line, the other is saturated vapor line. so the region in between these 2 lines is called the mixture of saturated liquid and vapor.
http://highered.mcgraw-hill.com/sit...earch='mixture of saturated vapor and liquid'
There is also statement that says the temperature of a substance which below the boiling temperature (saturated vapor) is called a subcooled liquid. So, that means its a pure liquid (without existence of vapor)?
"[URL
My question here is, if it is in the region of mixtures (which mean both liquid and vapor is in equilibrium), and the region of mixtures is below the saturated vapor line (boiling temperature), how could it be subcooled liquid (pure liquid) in the second statement?
So, what is it if the substance phase is in the mixture region under certain temperature and pressure and volume? Do you all understand what I mean, me myself already so confused!
It is helpful to look at a P-T diagram.
The subcooled liquid is 'below' the saturation temperature at a given pressue. In the saturation region, there will be a part that is liquid and a part that is vapor, depending on the total enthalpy (or specific enthalpy) of the mixture. As heat is added to the mixture, the energy goes into a phase transformation at constant temperature (and pressure). Once the mixture is transformed to saturated vapor (100%), further heat (energy) addition makes the vapor superheated and the temperature increases.
In a gravity field, the denser liquid sits below the vapor. In a flowing system, .e.g a vertical heat exchanger or steam generator, steam bubbles could mix with the liquid. There are various flow regimes according the relatively amounts of vapor and liquid and flow speed.
http://www.egr.msu.edu/~somerton/ME201_sec3/CompSubstance.pdf#search='mixture%20of%20saturated%20vapor%20and%20liquid'
First of all, I just noticed you have URLs included in the post which you've accidentally hidden by your formatting (I've fixed them in the quote of your post). But having just noticed them, I haven't yet looked at them. I imagine this is just the standard TV diagram for the water-vapor system.
Secondly, the subcooled liquid is the region to the left of the 2-phase region. Hence, it refers to the liquid at temperatures below the relevant point on the saturated liquid curve. Remember that boiling begins as you enter the 2-phase region from the left (ie: as you pass the sat'd liquid curve).
Still confused...
I am still not so understand. In a situation where the temperature of liquid is 60oc, and the boiling point of that liquid is 120oC. Can I concluded that the temperature is a pure liquid (not vapor exist)? So as long as the temperature of the liquid is below the boiling point of the liquid, it is 100% liquid?
I check the data of boiling point for H2SO4 and NaOH in the Perry Chemical Engineers' Handbook, page 2-302, there are figures to show the percentage of conc against enthalpy and temperature. For H2SO4, the 60oC is below the boiling point. For NaOH, the 60oC is at above of the saturated solvent line. What does it means? Are both of them in liquid form for that temperature or...?
Thank you!
  • · Replies 0 ·
  • · Replies 16 ·
9K
