| Thread Closed |
question about USA electrical system |
Share Thread | Thread Tools |
| Jul2-06, 11:04 AM | #1 |
Hello,
I live in Europe in house we use 3 phase (230 V every phase, 400 V voltage between phases) and null. I heard that in USA there are two phases (120V phase, 240V between two phases) and I wonder if that is true. Do they use 3 phase power transmission to homes or what? Thanks |
| Jul2-06, 11:34 AM | #2 |
I don't know about the US, but you have to pay extra to get 3-phase in Canada. Standard household input is 240VAC 2-phase. That's only used for heavy appliances such as driers. The normal outlets are 115VAC.
| Jul2-06, 12:55 PM | #3 |
Micko, I'm not sure I understand what you are talking about concerning how Europe is wired. I would assume that the voltages you mention are in a wye configuration and not delta? The null being the center of the wye?
- Here in the U.S. it is typical to have SINGLE phase running into your house. It is NOT 2 phase. This is a common misconception. There is a single pair of wires feeding the primary side of the transformer. The secondary side has a center tap which is referred to as neutral. It is bonded to the earth with a ground rod. Each end of the secondary winding is obviously 120 volts to neutral and 240 volts between themselves. 3-phase power costs more to have run to a building. Commercial buildings such as offices usually have 3-phase wye connected transformers and industrial buildings which use heavier machinery usually have delta connected transformers. |
| Jul2-06, 01:20 PM | #4 |
| Jul2-06, 06:38 PM | #5 |
That ratio correspondes to the 208/120 volt wye setup in the U.S.
| Jul2-06, 07:48 PM | #6 |
Admin
Two phases come into the typical US home with a neutral line. Line to neutral voltage is 120 and line-to-line is 240 V or thereabouts. Line to line voltage is used for certain appliances like stoves/oven and clothes dryers.
See - http://kropla.com/electric2.htm - various countries http://en.wikipedia.org/wiki/List_of...nd_frequencies |
| Jul2-06, 11:30 PM | #7 |
Recognitions:
| Jul3-06, 09:21 AM | #8 |
Recognitions:
| Jul3-06, 12:41 PM | #9 |
| Jul3-06, 12:52 PM | #10 |
Recognitions:
You guys are a bit confused by the term "phase." The basic input to a house is two legs (two hot wires) of a single phase. You have a double tap on the transformer with the ground in the center. There should be no phase difference between the two AC forms in your electric panel.
| Jul3-06, 02:59 PM | #11 |
| Jul3-06, 03:39 PM | #12 |
| Jul3-06, 05:12 PM | #13 |
Recognitions:
| Jul3-06, 05:33 PM | #14 |
Admin
I seem to remember the electrician talking about two phases, but then that is a different reference to the 3-phase distribution system. Adding to the confusion I found this: Sorry for the confusion. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: question about USA electrical system
| Help needed on to convert a typical mass damper system to electrical model-Urgent | Electrical Engineering | 1 | ||
| Making analogy between fluid mechanical and electrical system | Classical Physics | 4 | ||
| Electrical Ignition System | Electrical Engineering | 9 | ||
| An electrical question | Electrical Engineering | 1 | ||
