Acceleration Problem: Calculating Force of Pet 2
  • Thread starter Thread starter dimava
    Acceleration
The problem involves calculating the force exerted by one of two pets pulling a wagon, given specific angles and a mass. The scenario is set in a frictionless environment, focusing on the forces acting on the wagon as it accelerates straight forward.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to find the tension in the ropes and the combined forces acting on the wagon. There are attempts to calculate the X-components of the forces exerted by each pet, with some questioning the assumptions about the direction of acceleration.
Some participants have provided hints and shared their calculations, but there is no explicit consensus on the final force value. Multiple interpretations of the problem setup and calculations are being explored.
There is mention of an attached picture that is not visible in the thread, which may contain additional context for the problem. Participants also reference different approaches to calculating the forces, indicating a variety of methods being considered.
dimava
Hi guys,
I have a homework problem which I can use some help with:
Lisa harnesses two pets to a wagon. The mass of the wagon is 12 kg, and it rolls without friction on a horizontal floor. Pet 1 is pulling at 15 degrees left of forward with the force of 5 N. Pet 2 is pulling at 30 degrees right of forward. How much force does Pet 2 exert if the wagon acclerates straight forward?
I also attached a picture
thanks in advance,
Dimava
Well, I'm kind of lazy to do actual math for you, but I will give you hints on doing it.
First off, when you got two pets moving in different directions like that, you will definitally want to find the tension in the ropes to the wagon. By finding the tension caused by the pulling, you should be able to find the combined force on the wagon.
I think I got it, does 2.588N sound about right?
I don't know where this attached picture is, but...
Code:
 \15|  |30/
F=5\|_ |/F=x
   | \\ | <--- Wagon
So basically this is how it has to work. Since the wagon is going to accelerate straight forward, you want the X-Components of each force which pet 1 and pet 2 exert to be equal and opposite, and hence no acceleration in either the left or right direction.
the X-Component for pet 1 will be 5*sin 15. The X-Component for pet 2 must be equal so:
5*sin 15 = x sin 30
solving for x:
x := (5*sin 15)/(sin 30)
this will give you the force which pet 2 exerts on the wagon
Or at least this is how I interpreted the question.
edit:Ok, you posted heheh. Yes, that is the same answer as I got, so I'm assuming you did it correctly :)
I used almost the same thing, but did the cos of the supplements but same idea, thanks for your reply :smile:
