Motion Control Device Selection
The discussion centers on selecting a motion control device to drive a stepper motor using a Xylotex-brand motor controller. The user experiences issues with the PC's time clock affecting motor movement stability and seeks a dedicated controller that can receive commands from the PC and provide feedback from a linear encoder. The Xylotex controller operates on TTL logic with specific voltage requirements, necessitating a compatible controller for optimal performance.
  • Understanding of stepper motor operation and control
  • Familiarity with Xylotex motor controller specifications
  • Knowledge of TTL logic levels and signal requirements
  • Basic programming skills in C for PC communication
  • Research dedicated motion controllers compatible with stepper motors and linear encoders
  • Explore options for programming interfaces to communicate with motion controllers
  • Learn about feedback mechanisms in motion control systems
  • Investigate alternatives to Xylotex controllers that may offer improved performance
Engineers, hobbyists, and developers involved in robotics or automation projects requiring precise control of stepper motors and feedback systems.
heepofajeep
Currently I am using a pc to drive a stepper motor through a xylotex-brand motor controller. The problem is the PC's time clock just doesn't allow for steady movement.
What I need is a specific controller to handle the signal to the motor. All I want the PC to do is send a command to the controller saying "go here". I just do not have any experience with this, however, so your expertise would be greatly appreciated. I just need to know what device to use to enable smooth movement of the motor. Also, I would really like the controller to take in feedback from a linear encoder.
FWIW, the xylotex controller uses simple ttl logic, with a 1.5v max LOW signal & 2.9volt min HIGH signal.
Thanks!
Can you post a link to your motor info and controller info? What OS are you running on your PC? Are you able to do some programming on your PC in C?
