Double Integrals - Volume vs. Area
  • Context: Undergrad
  • Thread starter Thread starter Gramma2005
    Area Integrals Volume
A double integral can yield either an area or a volume depending on the function being integrated. When integrating a function f(x,y) over a region with respect to dA, the result represents the area of that region. Conversely, if f(x,y) represents a height above the xy-plane, integrating f(x,y)dA provides the volume under the surface defined by f(x,y). The interpretation of the double integral is contingent upon the context and the specific application of the function.
  • Understanding of double integrals in calculus
  • Familiarity with functions of two variables
  • Knowledge of area and volume concepts
  • Basic integration techniques
  • Study the application of double integrals in calculating areas
  • Learn how to interpret double integrals for volume calculations
  • Explore specific examples of functions like f(x,y) in real-world applications
  • Investigate the use of triple integrals for three-dimensional volume calculations
Students of calculus, educators teaching integration techniques, and professionals applying double integrals in fields such as physics and engineering.
Gramma2005
I am confused about when a double integral will give you an area, and when it will give you a volume. Since we are integrating with respect to two variables, wouldn't that always give us an area? Don't we need a third variable in order to find the volume? Thanks for the help.
Hello Gramma2005,
it depends on the function you are integrating.
Let's take a look at the function [tex]f(r)=4\pi r^2[/tex].
Yet the following integral, (only integrating with respect to one variable!) can be interpreted as the function for the volume of a sphere depending on the radius r.
[tex]F(r)=\int_{0}^{r} f(r') dr'[/tex]
Regards,
nazzard
A double integral will give you an area when you are using it to do that!
A double integral is simply a calculation- you can apply calculations to many different things.
I think that you are thinking of the specific cases
1) Where you are given the equations of the curves bounding a region and integrate simply dA over that region. That gives the area of the region.
2) Where you are also given some height z= f(x,y) of a surface above a region and integrate f(x,y)dA over that region. That gives the volume between the xy-plane and the surface f(x,y). It should be easy to determine whether you are integrating dA or f(x,y)dA!
But that is only if f(x,y) really is a height. My point is that f(x,y) is simply a way of calculating things and what "things" you are calculating depends on the application. Sometimes a double integral gives pressure, sometimes mass, etc., depending on what the application is.
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 29 ·
