Understanding Moments of Inertia & Tensors
The discussion revolves around the concepts of moments of inertia and tensors, exploring their definitions, mathematical formulations, and conceptual underpinnings. Participants engage with both theoretical and practical aspects, including the derivation of moment of inertia and the nature of tensors, particularly in the context of rotational dynamics.
  • Some participants express confusion about the conceptual basis of moments of inertia, questioning why the formula involves squared distance terms.
  • One participant explains the moment of inertia as a summation of point contributions, leading to the formula I = ∫r²dm.
  • Another participant attempts to derive the moment of inertia from torque and angular acceleration, suggesting a relationship between linear and rotational dynamics.
  • There is a discussion about the nature of tensors, with one participant defining a second-order tensor as a square matrix that can be contracted with vectors.
  • Some participants suggest that the moment of inertia can be derived from conservation laws, though this remains an open question.
  • One participant mentions the parallel axis theorem as a useful tool for calculating moments of inertia for complex bodies.
  • Another participant discusses the inertia tensor as a concept that extends mass to rotating systems, emphasizing its role in calculating kinetic energy and angular momentum.
Participants express varying levels of understanding and agreement regarding the derivation and conceptualization of moments of inertia and tensors. There is no clear consensus on the best approach to explain these concepts, and multiple competing views remain present throughout the discussion.
Some participants acknowledge limitations in their explanations, such as assumptions made about forces acting perpendicularly. The discussion also highlights the complexity of deriving formulas from first principles, indicating that certain steps or definitions may be missing or unclear.
This discussion may be of interest to students and educators in physics and engineering, particularly those exploring rotational dynamics, moments of inertia, and tensor analysis.
enigma
Staff Emeritus
This may be a sort of odd question.
I know what a moment of inertia is. I know what they represent, I know how to use them, I even know how to calculate them from scratch if need be.
But I don't know why they are what they are.
Why is it that this weird value with seemingly random d^2 terms provides the mass distribution about an axis?
Probably more to the point:
What, conceptually, is a tensor?
The definition from which you calculate them from scratch tells you a lot. The moment of inertia about an axis due to a point mass is (dm)r2. Those factors for different shapes arise out of the simple adding up of all the point contributions.
A second rank tensor (which the moment of inertia is) is, for these purposes, that which can be represented as a square matrix (3x3, in this case). It needs to be 3x3 so that it can be contracted with two 3-vectors, as in the expression for rotational kinetic energy, like so:
K=(1/2)ωTIω
where ω is a column vector representing the angular velocity and ωT is its transpose.
But why r^2 (other than to get the units to come out right...)
Again, this is a stupid -mybraincan'tcomprehendsomethingentirelyunlessIgetitentirely- type question.
I know what it does, I just don't know why it does what it does.
Okay well here goes an attempt to explain it:
  • So let's start with what we know. Torque by definition is force times the lever arm (or rxF to be more precise about it). This definition makes sense so we will start from here.
  • Given this definition of torque we can say that Στ = (ΣF)r. Here we'll assume, (just because I don't know how to do so otherwise) that all the forces are acting at the same distance and are acting perpindicularly.
  • Okay but the second term looks familiar to us. Newtons law ΣF = ma, so we'll substitute and get Στ = mar.
  • But now were dealing with rotations not linear motion so we'll remember that a = αr. So substituting again we find Στ = mαrr. Simplifying we get Στ = mr2α.
  • Since we know in rotations that Στ = Iα it follows that from above I = mr2.
Okay I know that's a little presumptious but does it help at all? I'll see if I can't find a better way.
AHA
THATS what I needed.
Thanks climbhi!
Oh, I thought you wanted to know why the coefficients to (mr2) were all different!
Very nice, climbhi.
Thanks, I'm glad that helped. So Tom do you have any ideas on how you could tweak with what I had above so that you don't have to make that assumption that I made. In other words can you generalize it to a system of n particles where the forces aren't neccesarily acting perpindicularly on these particle and get the result to come out I = ∫r2dm?
I'll do the first one now (nonperpendicular forces), and the second one tomorrow (continuum of mass).
Here's the "vector version":
Στ=ΣFxr
Στ=Σmaxr
Στ=Σmrαxr
Now note that rr=r2r,
where the italicized vector is the unit vector in the radial direction. So...
Στ=Σmr2αxr
That the product αxr gives the right direction is left as an exercise for the reader.
(That means I got to run!)
No argument with your approach to tensors, Tom. For my (engineering) students, I write:
A scalar has magnitude and no direction
A vector has magnitude and one direction
A (2nd order) tensor has magnitude and two directions
(one for the traction vector and one for the plane of action)
then:
scalar = 0th order tensor has 3^0 components (in 3-space)
vector = 1st order tensor has 3^1 components
2nd order tensor has 3^2 components
and so on to higher order tensors.
A (2nd order) tensor is then a kind of supervector.
Thoughts?
Ron.
Can't the form for the moment of inertia be derived from conservation laws?
Probably, I remember deriving it from first principles in my physics class but when i went back to check my notes I couldn't find it. I think we started by throwing a whole series of dots on the board and looking at what happens on each particle and then applying it to the whole system. I can't remember how to do it though. Anyone want to take a stab at it?
aXr doesn't give the right direction
its
rXa
The parallel axis theorem helps to extend calculating the moment of inertia to arbitrary 3-dimensional bodies.
Yes, parallel axis theorem = most convenient thing ever!
The inertia tensor originates from the study of (discrete or continuous) rigid systems, which are systems that preserve relative distances among their parts.
The inertia tensor does not involve any dynamical consideration (forces and torques) in its definition. It is simply a powerful tool to calculate both kinetic energy and angular momentum of a rigid system.
This tensor extends the concept of mass to rotating systems; mass determines how much speed you will gain when you transfer a certain (linear) momentum, inertia tensor determines what angular speed you will attain by trasfering a certain angular momentum:
p=mv
L=Iw
(Consider anyway that angular momentum depends on a prefixed pole and so will the inertia tensor; the problem can be simplified by breaking the motion into two parts one relative to the the center of mass the other treating the whole system as concentrated in the center of mass)
What characterizes a (3D real symmetric) tensor is that there are three direction of space mutually orthogonal that make the tensor diagonal. Hence a (3D real symmetric) tensor can always be thought as the rotation of these diagonal tensor. The way the diagonal tensor acts on the components of a vector is really simple since it simply multiplies each of the components for a simple number. The three numbers (principal inertia moments in our case) usually differ from each other; a scalar multiplying a vector can be simply thought as a tensor with three identical principal components.
To go back to the comparison with mass and velocity/momentum, there are conditions in which the (effective) mass will be different dipending on the direction of momentum (e.g. in many crystals) and these can be represented by an (effective) mass tensor. The same happens with many physical objects usually considered as scalars such as conductivity, index of refraction, etc.
The simplest way to see how each component contributes to the inertia tensor is by using a system constituted by a single mass rotating around a prefixed axis with (variable) angular velocity ω
Let us consider the origin as the pole for momentum calculation and a rotation axis passing through the origin/pole
L=OPxmv=OPxm(ωxOP)=m(|OP|^2-OPOP)ω=Iω
Now if you want to extend the concept to a system of masses you need to have a system in which the velocity of each mass point can be written as a vector product of the SAME angular velocity and position.
In general this is possible for rigid systems only after separating the contribution of the center of mass.
Mathworld link for angular momentum (http://scienceworld.wolfram.com/physics/AngularMomentum.html) could help but beware that it is full of little mistakes and it does not even mention that its calculation of the inertia tensor works only for rigid systems.
Hope this helps, Dario
  • · Replies 16 ·
  • · Replies 30 ·
